Hello!
I am new the machine polishing world but have wanted one now for quite a while. So yesterday I took the plunge...!
Yesterday I washed and dryed the Clio to my usual high standard and commenced testing on an inconspicuous part of the rear quarter. I started by using the black mequiars finishing pad and finishing 205 polish on a speed setting 1 and 2 at first. Some of the light swirling started to disappear.
Next I started again on the same area of light swirling and used the same finishing pad and then the 105 heavier duty mequiars compound and upped the speed to settings 3 and 4. The thing is an animal! The light swirling using this combination is now pretty much gone on my test patch.
As you can see from the photo I have bought mequiars products, the g220 v2, the three different cutting polishing and finishing pads, tape and both the 105 and 205 polishes.
I'm looking for advice on anything I should do when starting out:
- what compound to use
- speed setting
- which pad type
Just anything you can think of that will help me get results.
Thanks!
- speed setting
- which pad type
Thanks!
