Rogue
Seem to be going through a vast amount of coolant at the moment and I can't work out why. It seem to have started when I changed the thermostat over. I thought it was a leaky housing, so I sealed it up and it's all dry after running so that's not the issue.
Just had full service and Cambelt change and there was no mention of water leaking around the water pump or any sludge in the oil, so hopefully can rule out a faulty head gasket.
I had a feel around the engine bay whilst the car was running and all pipes feel intact and I can't feel any leaks, however I did spot some coolant on the back of the block under the top bleed valve (to the heater matrix?)
Any ideas? Car goes into the garage again tomorrow and they did spot it was when it was in last week but said I had a drip from the housing but I can't find anything.
Any ideas?
Any ideas?
