Little flat spot in 5th
Nah shouldnt be mate, vvt had kicked in then so you should be pulling like a train!
Hopefully someone with some more knowledge can explain why lol
Should be noticeable in all gears should it not?
The engine will give the flat spot, nowt to do with the gears.
Could it not just be that because 1, 2, 3 and 4th are so short that when you go into 5th it just feels like a flats pot and it's actually just the long ratio gear?
No no its long after changing into 5th..
I'm already in 5th pulling pulling pulling, then drops for split second then carries on pulling
Sounds a bit bizzare to me but could be a sign of the gearbox failing - isn't unknown when it comes to Renaults :/
Yeah some boxes have failed with less than that on these though its usually the synchos that fail on 4th
Can't see a flat spot being related to a gearbox issue in anyway whatsoever unless you have a slipping clutch. I will give mine a spanking at Cadwell on Friday if there's any flat spot I will notice it there.
Thought I noticed it yesterday and defo noticed it today
I gotta take it back to Renault for rear top mount to be done anyway so I'll mention it
Haha you do not want them testing that as that's above the national speed limit and even above the ban limit....
I'd try spark plugs :smile:
should just take off at 5.5k revs in fifth!!!!
right bang on max torque at those revs so should pull hard and clean!
