KTR Induction Kit Vs K&N Panel Filter
Depends what you're looking for. If you want to get every last 0.1 bhp out of your car then a panel filter in the factory airbox is going to be better. but if you want big intake noise then the KTR is what you want but you lose a bit of power on losing the factory cold air feeds
Reactions: Luc
Alright thanks realistically neither are actually gonna make a noticeable difference so I might just go with the ktr for the noise
The KTR kit adds some proper noise but not much, if any, performance.
I have not used a K&N kit so I could not tell you if there is any difference to a standard filter.
Thanks might go with KTR for the sound tbf cause neither are gonna add noticeable performance i doubt and itll look nice in the engine bay
Reactions: burrellbloke
It is about 200 from rpd,I definitely noticed a difference when I fitted mine,there is some HP to gain can't remember exactly as the stock airbox size is a bit restrictive.
