Really hope someone is familiar with the below and found a way to fix this.
Symptoms of the shudder at idle:
Especially when the engine is operating temperature at idling, every few seconds there is a shake of the engine. I first noticed the shake while waiting at some traffic lights - every few seconds I would feel a slight shake through the drivers seat. When looking at the engine itself, every few seconds the engine visibly ‘shudders’. As soon as I increase the rpm slightly, the engine runs smooth. No power loss, no increased fuel consumption. A/C turned off.
Symptoms of the vibration at 2300 rpm:
When I increase the rpm at standing still, revs go up smoothly but at around 2300 rpm, the engine starts to vibrate. Revving higher than 2300 rpm, the engine runs smooth again.
While driving, there is a slight power dip at 2300 rpm and engines stutters a little bit. Above and below this rpm range, engine runs smoothly.
Recently had a major service and the following was done but problem is still there unfortunately:
- New timing belt and dephaser pully.
- New spark plugs (OEM)
- New ignition coils (OEM)
- New injectors (OEM)
- New engine mounts, all of them (OEM)
- Throttle body cleaned
- All vacuum lines are ok (smoke test)
- New PCV
- New MAP sensor
- New O2 sensor
- Electrical connections coils and injectors visually checked and cleaned with contact spray.
- (As good as) new complete OEM exhaust system including exhaust manifold.
I was really expecting that with this major service, these issues should be solved but this is not the case unfortunately. Very strange is that these issues seem to have worsened after the service.
Any tips and/or solutions are highly appreciated!
Thanks in advance!
Verzonden vanaf mijn iPhone met Tapatalk
- New PCV
- New MAP sensor
- New O2 sensor
Thanks in advance!
