If Porsche made a hot hatch
Nice! I definitely agree with what you're saying about matching spring and shocks. Plus you'll be able to set the height exactly how you like.
Reactions: Bodyboarder81
That Megane is lovely. Can't say I've seen it about?
Only bought it around 2 months ago .... done a full suspension / brake overhaul on it . Already had exhaust / front mount / injectors , 290 bhp . He works for me and also is a semi professional paint Detailer . He’s paint corrected / ceramic coated around 4 of my cars . Porsche is being done this weekend coming :smile:
Reactions: lewishunter98
To
If not, get onto who you bought them from / Bilstein.
I am not sure if OEM ones will fit over the damper on the fronts, someone might be able to clarify here.
To be fair I’ve not removed everything, I’ll take a look later and I’m sure they are in there :smile:
Front dampers are inverted, so doesn't need a bumpstop (it is internal and hidden), so probably correct about not needing boot covers, I would see if OEM ones fit if you want to cover them.
It’s already been answered but it’s part of the damper on the fronts. You DO need to use the oem one on the rears though as well as the plastic dust cover. I’ve been running mine without a dust cover on the fronts for a while now and they’re fine.
Should have just read the instructions.... says it all on there . Typical man :oops:
Bilstein’s
Track rod ends
Drop links
Ani rotation links
Dog bone bush
Top mounts
All fitted and a health check from rentech ... which was all ok :thumb:
Only driven it back from them up the motorway but very positive so far . Think I’ll raise it just a touch but I’ll see how it feels first on a proper drive
C7EF54B5-8516-4750-B2C5-59234BEFE298.jpeg D5057694-3F01-4B0A-9462-91005D0A2116.jpeg
Sits well on the bilsteins. I’d not lift them personally unless they’re rubbing
