How much brake fluid......
I'm buying ATE super blue from ECP with the 30% discount code so 2l is only £20. May as well just buy 2 at that price I suppose!
Most say 1.5 litres but i usually find myself redoing all calipers just to use it up, two 500ml bottles does me.
1ltr is enough - if you put through 250ml per wheel it will easily replace all the fluid in the pipes...
Where can i find discount code?
I think it's ended now.
Just an update, I used about 1.5 litres, but I did bleed the fronts twice (I had to refit them part way through the rebuild process as my paint didn't turn up!)
