I get a little chattering etc on start-up when cold but nothing noticeable once warm.
You'd be a brave man to take on installation yourself, its a pig of a job. Better to pay a specialist who has experience in fitting them imo. Allow about $3k-$4k all in to do the job properly.
However once you get it on track, experience the excellent power down & see the improvement in lap times its certainly worthwhile.
New improved top mounts on their way...
[/URL][/IMG]![]()
Wow 3-4K!! I was thinking 1.3k ish for the diff landed and 1k absolute tops to fit it. Possibly not. And also very jealous of those top mounts...
A little feedback in usable numbers that some may find of interest (I keep detailed info of all my racing)...
Competed in a hillclimb today that I had the class record in at 85.76 seconds set last November. Today I reset that record to 80.03 in very similar conditions.
Where did the 5 seconds come from ? ...
Forget about driver improvement (I'm competing every 2 weeks or so in this car & have done for years so I'm pretty consistent).
So here's the changes to the car since the previous event... ive fitted a new intake, removed the air con, changed my brand of semis, new top mounts & fitted the Quaife.
I believe the diff along with the new design semis was responsible for the majority of the time gain.
Food for thought & reassuring that it was money well spent.
Semis are Hankook Ventus TD Z221... http://hankooktyre.com.au/Product/MotorsportTyreSemiSlick.aspx?pageNum=1&subNum=5&ChildNum=3#Z221
Intake is the Ktec one...it has improved bottom end torque surprisingly.
i was told to keep my hands of the intake on a clio ... i see KTR now offers an intake for a lhd-clio. after your report, i'm tempted again.
can you run whatever semi's you like?
what's different from the older top mounts?
5 seconds is massive. i bet you're well chuffed.
For semis guys, pls take into consideration the Dunlop Direzza 03G tires! Excellent heat management, while my mates on Toyo R888 have to have a cooling lap in 20 mins session, mine does not overheat! I took [MENTION=3629]simo[/MENTION]'s advice from here and it's well worth investment!
And yes, main factor is always the fresh rubber, but we are not in formula1 so we can not change in every 20 laps
[MENTION=50926]alex_hazard[/MENTION]: to instal the quaife, you have to remove the gearbox, remove open differential, install quaife, change the clutch bearing most possibly, change the engine mount bracket, fit gearbox, it's a massive exercise with serious labor time and cost.
Will definitely be considering a set of 03G's for my next set of semi's. They are quite expensive though.
Found the heated screens Ricky Evans Motorsport sells online.
Has anyone had any experience with the effectiveness of these heated screens ?.
Ordered one and awaiting delivery, but not heard anything bad about them. Mitchell at Pro-Line put me onto them, he may have some experience of them from his previous "ford" life.
A new set of Nankang AR1 semis to try out arrived recently...
Interested to see how they compare to the previous semis i've used on this car (Advans - Hankooks - Nittos). Yes these are cheap (handy when your replacing them 2 or 3 times a season) but they are still soft & sticky so should hopefully be ok.
