Steve! How are ya mate? Haven't jumped on here in quite some time and in that time, I see you've transformed your already stunning ride into prob the best 200 I've come across to date! Awesome job mate!
I've noticed the most difference with the front strut and the Cup Racer's front anti roll bar. Rear strut and ARB didn't notice so much because I had to run in the engine so I couldn't push it hard.Has definitely stopped the movement/flex in the subframe pick-up points to a degree. Not a big difference but none of these braces ever are, as part of a package with the other strengthening pieces it's worth doing imo.
I've noticed the most difference with the front strut and the Cup Racer's front anti roll bar. Rear strut and ARB didn't notice so much because I had to run in the engine so I couldn't push it hard.![]()
That's interesting.
Ive not considered fitting the front strut brace as the strut towers are already a structural part of the bulkhead/firewall so I didn't see how adding a strut brace could do anything at all...I may have to rethink that if you are convinced it helped?.
As for the rear strut brace, I fitted it simply for use as a harness bar till I got the purpose built Ktec one.
Given that my car is primarily for track use I see no value in fitting a larger front sway bar as it will just increase understeer in my car.
On the other hand the rear sway bar I found has helped increase lift off oversteer allowing more cornering adjustability.
Wow, very impressive accomplishments there Steve! I'd love to get involved in racing too but just don't have the coin to keep the maintenance up nor the balls just in case something goes wrong and I'm left with a massive bill. Looking to start ramping up the mods myself. I've only added a tune from Henk since we last spoke. So all in all, ITG induction kit, Akra, custom map from Henk and braided lines
Never had a Gripper LSD so I can't compare the two but I heard that it was better for racing too. It needs to be serviced though.If my car scrapes at all it rubs the exhaust resonator due to its positioning in the centre of the car. The lower brace hasn't scraped at all since I fitted it, probably due to the positioning being closer to the front wheels. My car is about 20mm lower than 'cup' height so probably not as low as yours but I doubt it would be an issue.
I am tossing up between fitting the Quaife & Gripper diffs for next seasons racing, i understand the Quaife behaves like an open diff when a wheel is unloaded meaning it will still spin up a front wheel whereas the Gripper works much better in such applications, im interested to hear your experience with the Quaife.
