Help required please??
Ideally i wont to find out what tge issue was, just incase it happens again.
Luckily enough i may have sourced a wiring diagram which will allow me to check each connetion correctly.
Sent from my SM-G935F using Tapatalk
Is it worth checking all your earth straps? I've had cranking and fuel priming issues on previous cars that turned out to be bad earths. I'm not sure where they ALL are on these cars, but noticed there are a couple around the battery area, one to chassis and one to the gearbox. Just something to rule out ??
One for the box I've had totally loose for a few days and didn't make a difference, must be earthing through an engine mount
_________________________________
GW 197 ex Michelin Road Cup Racer -> Track car/Sprints
http://www.clio197.net/threads/gw-197-ex-michelin-road-cup-racer-track-car-sprints.53560/
