If you're still out there, thank you!! This worked for usUgh, it looks like the solenoid is gone, not looking forward to pricing a new one. I got it open in the end thanks to a cached google post. Basically there's no easy access release, you need to take off the interior panel that the right rear seat belt feeds through. it is the white one and comes off easily.
the text is below, I will attach some pics too.
"This happened to our 55 plate clio this weekend. And I felt compelled to join this forum to post a bit of useful/accurate "how to" information.
On our model, it a regular bog standard clio, there is no emergency release pulley or clip despite what the previous posts say. I phoned the renault dealership that sold us the car and they confirmed this.
It is possible however, as I discovered eventually, to squeeze ones hand onto a tiny element of the central locking solenoid that locks the fuel tank door if you unclip the trim around the rear A frame where the fuel door is situated.
On our clio (with the trim removed) we seem to have an airbag unit just the above the seat belt unit. To the right and very slightly up from the airbag gas canister it is possible to get ones hand in to a small gap (this will be directly above the fuel door. Here you can feel what seems to be the top of a small piston or plunger. This is the lock device for the fuel door which you can pull up. This should "manually release the fuel door and you can fill up and then sort the route cause of the problem.
DO NOT attempt to tear off the door, there is no way for it to come off without causing major damage despite what you may think.
Hope this helps
Vaz"
Johnrellis your pics help a great deal! It’s hide away and almost no way to see it! I just use my hand to feel everywhere until I feel the lever exactly like your pic. Salute to your extra effort to put up the pics!Ugh, it looks like the solenoid is gone, not looking forward to pricing a new one. I got it open in the end thanks to a cached google post. Basically there's no easy access release, you need to take off the interior panel that the right rear seat belt feeds through. it is the white one and comes off easily.
Hope this helps
Vaz"
I have a 2008 Clio which I don’t want to spend money on unnecessarily. There is no ring pull mechanism in the inner trim. The steps above therefore worked really well for me. Thank you.Fuel cap stuck on Renault Clio Mk III (05 onwards)
This mechanism is a piece of crap - and so is the way the body is put together, thus it's easy to get to the locking mechanism in an emergency:
1. There is NO pull ring mechanism in the inner trim or behind the parcel shelf.
2. The Outer door trim on the fuel cap is only held in place by 5 or 6 plastic slides. Pull panel gently towards you and slide it from RIGHT to LEFT (towards back of car). It should move without too much force.
3. You can now see the locking pin at the top of the inner fuel door. Use something long and thin to move it UP.
4. Put the trim back on ... it'll clip into place.
Sorted... at least until the next time
Had this on an away trip recently with car loaded up with track wheels! Not pleasant. New solenoid today
Gave the job to Alex. Didn’t even consider having a go myself! Think it’s a quick job if you know what you’re doingHow difficult was it to fit a new solenoid? My one’s in for its MOT and the fuel flap’s stuck closed again![]()
Sorry,I see that no one removed the cap cover and opened from outside? So the filler cap whis is in color of the car can be removed by sliding to the rear of the car, than you see internals and with a flat screwdriver you just push up locking pin. That is how I solved my problem. Good luck to all.
