Heating issues: Fan not turning on
Kalamat88
Hi all,
The Clio is having problems overheating due to the secondary fan not coming on.
You wouldn’t realize it in short 10-15 minute trips- it rides fine on the highway, zero issues with the constant flow of air coming in, but slowly but surely in stop and go traffic, the temperature warning goes off.
I’m starting to think I unplugged something accidentally or maybe a fuse? I checked a few fuses but that could still be a problem, too.
Any ideas on where to check first?
These two look plugged in and good to go- anywhere else I’m missing that I should check connector-wise?
As always, thank you all!
I don’t have any needle nose pliers so I wound up doing this.
The fan didn’t come on at all despite the engine fully warmed up and the AC on. I’m this close to taking it to a shop as I don’t do well with electrical stuff.
Here’s also the connector to the fan- it was a bit damp so I spray it with some compressed air and let it sit.
