Had this same issue recently. Garage was unhelpful. Eventually I was able to see the pool of water during some bad weather and could even see the connector sat in it. You can access the drainage hole on the passenger side sufficiently without unscrewing the wipers I found.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
