Wiring still not complete as I wait for fire extinguisher and also looking at adding a few more ‘extras’. Instead decided to gut the doors and finally embrace the poly glass.
It wasn’t actually too bad of a job although getting the glass out is a real pain if you have left the window fully up and gutted the electrics
Decided to leave the top bar but take out the cross member which is now replaced by the cage door bars. Original weight was around 36kg, by my calculations I now have it down to 25kg, so you can get about 11kg off each by gutting / poly / door cards. Doesn’t sound like much but they feel noticeably lighter on opening/closing, this puts me at around 1090kg dry.
____
I posted on fb asking for advice on replacing conrod bolts / bottom end refresh, I got all sorts of rubbish in response ranging from do it through to don’t do it but create a savings account, luckily Alex W replied…
The car is now on close to 65k and with it spending its life bouncing off the limiter I am keen to keep her going strong plan was:
- Sump clean / gasket replacement
- Take off the rod bearings / inspect
- Take off oil pump / inspect
- Replace conrod bolts with ARP
The sump was rough, even after draining there was about 300ml of dregs, definitely recommend taking the sump off and cleaning. Nothing metallic that I could see or filter just crappy oil.
The oil pump was worse, scoring on the inside and the gears themselves seen much better days, speed dial 1 to Nick at PMS for a new one.
I then took the bearings off, they don’t look great, no scoring but obvious wear across the full width, back to PMS for new bearings. The journal on the crank is better with minimal wear and no scoring on any of the faces. This was when I started getting a bit out of my depth, enjoying the process I invested in a HPA course and have now gone down a very deep hole in learning about engine building. My background is actually Mech Eng so it’s not completely alien but my degree was focussed very much on the maths / theoretical side of engines so I have a lot to learn.
Plastiguage ordered so I could check the bearing clearance with the new bearings, seems to be a dark art. I ordered standard OEM bearings so I could get a base measurement, worst case I then have to purchase undersize to handle any wear. Luckily however they have come roughly in the middle of spec at ~0.04mm, with the spec being 0.02-0.07mm (r3 engine is 0.07-0.09)
The plastiguage is also even across the journal so I am confident in the crank, only slight issue is my rod/crank lateral clearence which is at the top end of spec at around 0.35mm against spec of 0.02-0.04mm so right at the top end. Not much I can do about this without new crank/pistons but tbh I see no extreme wear so I wonder if it was like this from the factory.
Hopefully the replacements / upgrades will keep her going for another 65k. TBC as I am currently waiting for a few parts before torquing her back up.
