Fuel regulator 197
Where is the fuel regulator situated on the clio 197. I took the top off the engine so i could see the injectors thinking it was on the end of the fuel rail. Nothing..........?
Depends if you wanna do it the proper way or start chopping the metal out under your rear seats :tearsofjoy:
This Is the part I was given. Mines a 2008 rs197. This go in the fuel pump then.
I have another fuel pump spare I could fit it in. Yes mines plastic. How do you get the plastic but off....?
This is the spare fuel pump I have.
How the heck do you get the plastic bit off where the regulator is.? Does it screw off or gotta prize it off. Is the silver pressure regulator right for mine....? Or have the donuts sent me the wrong one. There discontinued from renault
The silver one is incorrect as it has the reference port on it. That looks like an FPR that would sit in a fuel rail.
You can’t get the FPR out of the plastic items without bastardising it unfortunately.
Why do you think you need a new one? You could just swap out the bottom portion with the FPR in from your spare one.
