"Front Splitter Idea"
I'd bond it on mate like u said would keep it looking oem and a little cleaner, hopefully won't stick out far off the original lip. Looking forward to seeing what it turns out like mate
the cleaner look is what i'm after mate,just had a look at my oem splitter and it actually sits back by about 1mm so hopefully bonding the new strip on should work as its only 1.5mm thick,i'll offer the strip up first and go from there,if not it can always be used as a bondage whip if it doesn't work! ha
buy a hot glue gun and glue it on. will be permanent until you decide to remove it.
