Has anyone else experienced this little problem I've currently got, I fitted a set of 13cm components that I had fitted in my previous car and the mid-bass woofers, depth wise fitted OK so went ahead and fitted them.
But after fitting my drivers door window at random would no longer go down or up properly either by one-touch or holding button down, you would have to keep releasing and pressing the button and then window would only move a few inches at a time.
On further investigation today, clearance and speaker rubbing is not the problem but I've found on the outside edge of the plastic speaker housing (still inside door cavity) is a connector block (maybe more) for the window control and basically when the back of the woofer get's within an inch of the connector the problems occur's but if I hold the speaker further out window operates fine so assume the magnetic field from the magnet is affecting this.
I noticed the pioneer upgrade seems to have it's magnet on front of woofer can anyone confirm this as it would then make sense if this window connector/controller can be easily affected by magnetic fields for them to do this.
Only options i can think of are
1. buy the pioneer speaker
2. relocate this controller and re-wire which will probably screw the warranty I have
3. find something to shield with but the metals that I know of such as lead would be bulky etc. and so not ideal for fitting into the tight space available
