So I may have driven through a bit of a flood this weekend. Got through it OK carried on with out any problems but then this morning out of the blue on my daily commute the engine died.
Cars been towed to my local dealer. First report showed low comp on three of the cylinders. Possible bent con rods (bugger) might just be the head gasket (if i'm incredibly lucky, which I'm not) I've told them to investigate further head off n all that jazz to asses the full damage. I'm currently prepared for a potentially massive bill but what dose every one think is the best course of action? If the bottom end needs a rebuild is there any worth while power mods to be made? Cost of OEM con rods n pistons over after market or even forged? Personally I don't see the point forged unless I plan on going for big power but the ktr forged kit is actually cheaper than OEM.
On the plus side my r27 with only 27k was due its 5 year cam belt change any way so I should be able to save a few Bob there :headphone: and I've haggled the dealer down to £50 an hour labour from there usual £75.
If I do need an engine rebuild or at least bottom end can any one recommend a reputable tuner in the notts area?
Cheers all :thumbsup:
