Today I met a man who has enormous knowledge on Clio suspensions, as he was the tech man on Clio Cup series in Hungary and still runs cars on track competitions.
Based on his suggestion, his garage set up my suspension as follows:
Untitled by Tamás Flatsker, on Flickr
The max front camber with @simo top mounts is (2.3)ish degree
Front open/negative to is (1)mm open on each side
Rear camber is a surprising (1.3)ish negative
Rear toe is a 6.9mm positive/close toe
So the next step is to change the rear toe with shims to 2mm, meaning 1mm each side, which will change the car when cornering!
When I will get used to it, I will go down to zero and later try the negative/open toe at the back
Any thoughts?
Any thoughts?
