I like to see the plates (metal) in the proper plastic surounds (rear) and on the fron i used the number plate sticky pads however these are rubbish once used once however do not un stick due to heat.
You got some metal ones havn't you Roy, me too can't wait to see pics of yours. I just drilled mine and used the original screw holes in the bumper. Not interchangeable very quickly but more secure.
Had some on my old car and had them on with sticky pads and in time they came off. So I drilled some holes in mine and screwed them on with colour coded caps (white and yellow)
Yes Angel will get some pics up when they are fitted.i don't want to screw them on so I can get them of easier to clean
Some one told me like A2ON they do sleeves to put them in I will have a look
I used some sticky pads from the local motorfactor, they work good. But if you want to take them off quite frequently, I would say your best bet is to either screw them on or buy some cages and screw them on.
