ex Nimbus r27r #2054
or defective bearings! the other three set of bearing was perfect!
many many many r3 access and maxi 230 had this problem and renault sport solved the problem with these pieces..
in the r3 rally world was a frequent problem...
r3 with "slick" tyre has the same sump. i run always with FULL oil level.
if the other 3 are perfect i would say its a oil supply issue/fault - oil surge in the sump causing oil starvation on that main bearing
the change in the crank and the bearing will be to make sure this isnt an issue - the crank will have bigger/better oil ways and improved oil leakage and the bearing will be of a better/harder wearing material
under "normal" conditions the standard crank and bearings seem to be ok
i run track days always with full oil level :worried:
news of 5min ago.... my new couple is arrived!! So next week i'll hope to play with my clio!
Looking good, is the new 'couple' for reducing the gear ratios?
And which pistons are you using? They don't look standard?
renault sport have make a update to r3 evo2009 (250cv) for delete these problem: new crank, new connected rods and new bearings (500€ the set!!)
Are you sure about the price? Do you have part numbers?
Crank, connecting rods & bearings for 500€ and it's from the R3 2009?
How long did you wait for the R3 Maxi bearings?
I can't order them in Croatia so i was thinking - can you order them in Italy and send them to me? I would pay you in advance via PayPal.
I'm trying to order them but Renault Croatia can't...
Ahahah 500€ only the bearings...
I fitted saenz connecting roads 290€ each.. Do you wanted them? I can buy them
It was strange to me that it was all so cheap...:smiley:
Can you get your hands on the R3 250 bearings? All of these:
P.S. Let's continue on MSN. :smiley:
these in your photo are of clio r3 230...
CLIO R3 250
N°12: 75€ each
CLIO R3 230
N°3 like ours 85€ all
@ 10 July i'll go at Balocco for an open pit track day!
It is a track that use for test many car and supercar, you know?
It is open 1/2 days in year for few people, is very difficult and secret enter in that track!
I'll go with 2 my friends that came with me to the ring. I hope to make many videos :wink:
