Had the 197 since January and had to take it for its MOT Monday . Was expecting it to go straight through ( which it did ) one advisory which is lower ball joint on near side ( want to get this done before it shags my new tires up) Can you replace the ball joint or is it part of the lower arm / wishbone?
Not done anything mechanical on her yet so not sure. Also got chance to have a look under the car while over the pit. Looks like the cat is still fitted then after that there seems to be a large bore pipe and a separate silencer before the rear scorpion exhaust . How easy is it to remove the cat? And what advantages / disadvantages are there
