My window did that once!! Was fine in the morning. Went to the shop. Came out to go home and it was being weird [emoji23][emoji23] Sorted itself out the next day though
Random as! Id have thought it might be caused by an electrical fault or bad earth, Ive seen it on other cars (BMW) after door seals failed and the comfort module got water damaged. Mine just didnt like that particular window switch! I guess the same applies the other way too, if you go Cup to Full fat doorcards the switches need swapping.
Where you based Doogle? Spotted Dartmoor, I’m in Exeter if you ever fancy a moorland blast.
Changing the oil was actually very easy and I now have a drain plug for changing my own engine oil too (never done it) but Ill give it a go at some point. The gearbox is definitely better, I felt it straight away even when the engine was still warm. When cold its dramatically better. I have a noisy release bearing so clutch pack needs changing. At almost 120k miles its done well!
Think i'm gonna change mine. Only thing putting me off is the crunchy box which means it'll need to be changed soon anyway. But its a pain in the morning getting into gear haha! Probably gonna go for redline too
Yeah I'll probably do it in the next few weeks. Have so many parts to go on/change. Brake fluid, lines etc. New shocks soon. Pretty much everything. Can't waitWell worth doing. Id put it on one of the top service items as a must do for any mileage car really. Mine was black but had no swarf in so I was happy. I didnt measure how much I got out but id estmate I got 1.8 litres back in. I still had a few millimetres of oil at the bottom of the 2nd bottle, and that was jack the car up on side to get more in. For you, getting most the swarf out is a good idea and will make it smoother, if only for a few months til you get the box done. Only took about an hour too.
Yep I'm really looking forward to itSounds like you'll have a new car! These are transformed when the basics are new. Suspension, engine servicing, brakes, etc. Not cheap to do though, especially suspension.
Small update, I bought the Redline MTL gearbox oil. I was determined to get 70w80 stuff before Redline changed to 75w80. I bought 2 bottles from Halls Performance online but when it turned up it was 75w80 anyway. I paid a little more posted than Opie Oils are selling it for annoyingly.
I changed the gearbox oil with the standard Elf NFJ last week and haven’t noticed any difference myself, still stiff to go in some gears and whiny bearing type noise like someone left the hot tap running. I’ll give the Redline MTL a go next time round. I’m not sure it needed changing really, only on 55k and a tiny amount of the oil was black with the rest looking like new.
I was visiting Dartmoor recently, some nice roads you have round your end! I'll let you know next time I'm there so you can try the Rentune seatbase.![]()
Nice progress. Some fabulous scenery in the photos. Imagine the roads are decent for a hoon!?
its like looking at my car,just before it was sold..so lovely..good maintaince is the key to a healthy motor..
got some hot wheels with pedals for nowThanks Pav, what are you driving now then?
| S | New owner Albi Blue 197 | New Members | 13 | |
| I | New Irish Member Albi Blue Clio 197 | New Members | 1 | |
197 & 200 albi blue hy500 07.10.23 | Spotted | 0 | |
Hogg's Albi 197 track car | Projects/Progress Threads | 47 | |
Albi Blue 197 Near Duxford | Spotted | 4 |
