Different exhaust tips?
Yeah I did, where the pinch bolts screw through the tips Thers 2 raised pieces inside I had to file these off as there pretty much an exact fit, it's very soft alloy so took no effort at all to file away n I just used 60mm jubilees to secure them in place, they took about 20 mins from box removal to fitted to the car
Hey Matt, I just bought 2 of these. Did you have to remove the diffuser to get them on? Cheers!
Sorry only just seen this mate.
No I left the diffuser on, there is a little bit of metal that will need filing down on the inside of the new tips - this will allow you to just push them on to the existing exhaust tips.
I just tapped mine on with a rubber mallet making sure they were far enough on to be secure, whilst making sure they were level with the opposite side. I think some people use jubilee clips to hold them on but I just tapped mine on and they've been on for 2+ years with no problems.
Just make sure they are on central to your diffuser holes so they aren't touching the plastic.
Reactions: seeka
Thank you mate! Hopefully mine will arrive today or Monday.
