Clio RS 20th mod in Japan
I would like to update my Recaro pics.
I lowered front end of the seatbase by 20mm using Japanese recaro sportster base frame and recaro adapter.
Japanese recaro frame is a little bit lowered considering Japanese physical.
Upholstery installed
Finished !! :bounce1:
very nice!
Do Recaro Japan do specific Clio subframes, to mount Recaro bucket seats? Like these:
http://www.rhdjapan.com/recaro-rs-gs-full-bucket-seat-61403
OR do you know if Bride list a subframe for the clio?
Recaro Japan do not supply subframes for clio197/200, so I imported recaro adapters for my Clio from Germany.
Some third party suppliers here have specific Clio subframes for Recaro, Sparco, Bride and etc.(for bottom mount and/or side mount seats) ,
but the seats with them will go to the window side by 30mm and its a big problem I think.
Hi masa, can you explain me how disassembly tge recare like in the first photo please? With photos is better!
:wink:
Oh its not so difficult. I dont have step-by-step photos,
1. remove seat base (remove 4 bolts beneath)
2. remove seat belt holes trims (remove 2 screws for each side)
2. remove seat back upholstery (pull the edge carefully)
:smile:
Hey Masa, could you share the product number for the subframe and adapters you are using? :wiz:
Ok, I am using
1. Recaro Japan Sportster seats
2. Recaro adapters from Germany
3. Original seat runners of my normal seats
product number of the Recaro adapters for clio3
68.92.19 (left seat) 135 Euro
68.92.29 (right seat) 135 Euro
You can download Pricelist Adapters and Baseframes (Konsolenübersicht).
http://www.recaro-automotive.com/de/service/kataloge.html
You can buy them from ebay.
http://cgi.ebay.de/RECARO-Sitzkonso...6986?pt=Autoteile_Zubehör&hash=item5638352efa
http://cgi.ebay.de/RECARO-Sitzkonso...3430?pt=Autoteile_Zubehör&hash=item3efb5b3ed6
Recaro adapters
Some pics of the right seat step by step assembling.
2. Recaro adapter fit to the sportster
3. Original seat runner fit to the recaro adapter
I thought it is a popular way to use recaro adapters to install recaro seats over there.
Here recaro Japan does not sell their adapters ,so I had to import them from Germany.
-You can not use recaro adapters to the Renault genuine recaro seats.
-You can not lower seat height with the recaro adapters. They are designed for aftermarket recaro seats to be the same height with the normal seats.
8)
thanks a lot mate!
i would like to lighten my recaro... theme are too weight! 20kg...
but the airbag are not too weight...
maybe the base??
So in order to lower my Recaro seats I need only those "2. Recaro adapters from Germany" or I need also a "1. Recaro Japan Sportster seats"?
