As most of you know i've had a the runt of the litter with the new clio rs 200T's.
had the car for a few months now and its been back to the garage 4 times since purchased.
now my opinions don't account for all Renault service garages but the ones in question are the mansfield service center and the dealership it was bought from (Bristol Street Motors) in Derby.
The faults were as follows;
- Engine fault lights on the dash including Check ESC, Check Hill start, Check Anti Pollution Filter.
- When the engine was cold the car would fail to select gears. It would judder and grumble until the engine reached temperature and it would run fine after this.
1st Service - they ran diagnostics and found no fault. gave me the car back after 5 days.
2nd Service - they ran diagnostics again and found that an ignition coil was faulty. they replaced this and i got the car back after a few days. unfortunately this did not solve the issue.
3rd Service - they had the car for a week and came to the conclusion it was something to do with the engine wiring loom. they said they had a play around and may of accidentally plugged something into place as they couldn't get the car to fault. i had the car for 2 days before it went to **** again.
4th Service - i took it back to the dealership this time as they have a Renault master technician on site. they fixed the car in 48 hours. they said they had replaced ignition pack 3 (waterer the **** that is) for all i know it sounds like they replaced the ignition coil. which is what the mansfield branch did on the 2nd service. Anyway, the car is running a lot better but I'm still experiencing some issues in the morning when the engines cold. i'm basically expecting the engine lights to come on again in the next couple of days.
This is my first performance car and my first turbo. should i expect some shoddy performance when the engines cold? or should i kick off and deem the car as unfit for purpose and demand a new one? the cars been at the service centre longer than I've actually driven it.
I've ruled out the Milltek exhaust system causing any issues. they assured me the exhaust doesn't affect any engine sensors. The faults were also on the car before the Milltek system was installed. its better to rule out any after market parts even if you know they aren't the cause.
whats the forums thoughts? put up or kick off?
