Hi, I noticed there were a few threads on the forum advising people on how to buy 197s. So I created this thread to bring the information together as I currently find myself in a position writing a list for a friend to go and check a 197, that he wishes to buy. So here it is.
Things to Check:
So straight away the engine SHOULD be cold, hopefully the seller doesn’t attempt to warm it up before you arrive.
1.Pop the hood make sure the engine is cold.
2. Check the service book, should have been serviced at least every 12K. Should be FULL. (high)
3.Check MOT history any advisories? Is it FULL? (medium)
5. ONLY turn the ignition on, after doing this check EVERY button in the car click EVERYTHING make sure it works clios have questionable electrics. Especially the window wipers they are PRONE to FAIL. Make sure all the bulbs work from outside the car as they are difficult to fix. (medium)
6. On the end of the right-hand indicator stalk there are two little buttons. These flick through the dash, Check the mileage is correct, check there’s a message that says ‘no message to display’ this means theres no errors. (low)
7. Right so driving TRY check third and fourth gear up and down shifts are the main issue usually but sometimes second gear to, make sure there’s no crunching in the gear box. Be ROUGH with the gear changes intentionally with the engine to see how it feels. But check all the gears slot home cleanly and with no thunks or graunches.(highest)
8. The clutch should be quite STIFF if it isn’t it could be signs of excessive wear. (medium)
9. Also Check passenger/driver seals (between the door and rear window) these are a common fault and the rubber cracks. (medium)
10. CHECK exhaust manifold has not cracked and the flexi pipe has not rotted through. (medium)
11. Also Steering link rods seem prone to wear, though this is cheap to resolve. A clunking noise from the steering can indicate a failing rack. (medium)
12. Drivers and passengers seat bolster, is it worn? (low)
13. If you have a jack take it jack the front tyres up and check the BALL JOINTS they are prone to fail on the clio. (medium)
All the little bits don’t matter as much if the car drives perfectly, use them to weasel the cost down, write down which of these things are there or aren’t there and build a case for the cost of the car using the check list.
MOST IMPORTANTLY don’t act impressed at all by the car in any respect even if you drive it and thinks its amazing keep it quiet.
These are all Clio specific checking points, the generic body check up, oil levels, oil cap checks etc still need to be carried out. Id like to think this list is exhaustive, but if anyone can think of anything I have missed please add it to the thread. Cheers Tom!
Things to Check:
