Clio 197/200 Torque Setting for Suspensions/Engine.
Engine
Note: Always renew stretch bolts and self-locking nuts
Cylinder head
Renew the bolts
Renew the gasket
Stage 1
30 (Nm)​
Stage 2
155 - 205 (°)​
Valve cover
Stage 1 (Bolts 13, 20, 22, 23)
8 (Nm)​
Stage 2 (Bolts 1 - 12, 14 - 19, 21, 24)
12 (Nm)​
Stage 3 (Loosen bolts 13, 20, 22, 23)
Stage 4 (Bolts 13, 20, 22, 23)
12 (Nm)​
Big-end bearing cap
Renew the bolts
Stage 1
25 (Nm)​
Stage 2
104 - 116 (°)​
Main bearing cap
Renew the bolts
Stage 1
20 (Nm)​
Stage 2
Sump
Stage 1 (Bolts 1 - 6)
15 (Nm)​
Stage 2 (Bolts 7 - 10)
18 (Nm)​
Stage 3 (Bolts 11 - 22)
18 (Nm)​
Stage 4 (Bolts 1 and 2)
18 (Nm)​
Sump (Gearbox side)
44 (Nm)​
Engine oil drain plug (Renew the seal)
20 (Nm)​
Spark plugs
28 (Nm)​
Oil filter
10-14 (Nm)​
Knock sensor
20 (Nm)​
Oxygen sensor
45 (Nm)​
Starter motor
38 (Nm)​
Alternator
25 (Nm)​
Camshaft bearing caps
10 (Nm)​
Camshaft gearwheel
30 (Nm)​
Crankshaft pulley
Stage 1
40 (Nm)​
Stage 2
100 - 120 (°)​
Ancillary drive belt tensioner
50 (Nm)​
Timing belt tensioner pulley
32 (Nm)​
Timing belt idler pulley
50 (Nm)​
Timing cover
Stage 1 (Lower section)
9 (Nm)​
Stage 2 (Upper section)
38 (Nm)​
Flywheel
Stage 1
30 (Nm)​
Stage 2
Exhaust manifold (Stud bolt(s))
9 (Nm)​
Exhaust manifold (Nuts)
30 (Nm)​
Inlet manifold
15 (Nm)​
Ignition coil
15 (Nm)​
Coolant pump
17 (Nm)​
Oil pump
24 (Nm)​
Engine/gearbox mounts
Manual transmission, TL4, 6-speed
Manual transmission drain plug
24 (Nm)​
Clutch pressure plate
20 (Nm)​
Suspension
Front drive shaft to wheel bearing housing
280 (Nm)​
Suspension: Refer to 'Technical drawings'
Wheels and tyres
Wheel bolts
(Clean the contact surfaces and wheel bolts/nuts; lightly grease the wheel centre taper only but do not grease the wheel bolts/nuts)
(Caution! Do not use power tools when screwing in or tightening wheel nuts/bolts)
Stage 1
30 (Nm)​
Stage 2 (Rotate the wheel by 180°)
Stage 3
140 (Nm)​
OE Wheel fitment Information
General Information
Loosen the wheel bolts with the wheel on the ground.
Use sockets with protective sheaths in order to avoid scratching the alloy wheel rims.
Clean the hub carrier using a wire brush.
Coat the wheel mating face with COPPER ANTISEIZURE GREASE.
Pretighten the wheel bolts to 30 N.
m , with the wheel suspended.
Torque tighten the wheel bolts in order to correct torque.
Important Information
There are two types of wheel bolts, do not swap them.
Do not strike the surface of the wheel using excessive force as this may damage.
Steering
Steering wheel
44 (Nm)​
Engine
Engine sump, including filter
5.4 (l)​
Cooling system
5.0 (l)​
Brakes : General data
Brake system
1.0 (l)​
Manual transmission
Gearbox refill
2.0 (l)​
Plug location (Drain plug)
Plug location (Filler plug)
Air conditioning
Air conditioning
Plug location (High-pressure connecting pipe (H); low-pressure connecting pipe (L))
Refrigerant
510 ± 35 (g)​
Air-conditioning compressor oil, system total
150 ± 10 (ml)​
Air-conditioning condenser (only when renewed), additional capacity (Quantity of oil recovered plus specified top-up)
30 (ml)​
Air-conditioning receiver/dryer (only when renewed), additional capacity (Quantity of oil recovered plus specified top-up)
15 (ml)​
Air-conditioning evaporator (only when renewed), additional capacity (Quantity of oil recovered plus specified top-up)
30 (ml)​
Each air-conditioning hose, additional capacity (Quantity of oil recovered plus specified top-up)
Suspension
Wheelbase (Hatchback)
2451 (mm)​
Wheelbase (Estate)
2575 (mm)​
Vehicle condition (Unloaded)
Ride height, front (Sport suspension)
A= 143 - 169 (mm)​
Ride height, front (Vehicles with Sports package)
A= 134 - 155 (mm)​
Ride height, rear (Sport suspension)
B= 241 - 273 (mm)​
Ride height, rear (Vehicles with Sports package)
B= 233 - 258 (mm)​
Toe-out, front
0°00' ± 0°10' (°)​
Camber, front
0°00' ± 0°60' (°)​
Maximum difference between the left-hand side and right-hand side
0°30' (°)​
Castor, front
4°30' ± 0°60' (°)​
0°30' (°)​
King pin inclination (KPI), front
9°40' ± 0°35' (°)​
0°30' (°)​
Toe-in, rear (Sport suspension)
0°10' ± 0°08' (°)​
Toe-in, rear (Vehicles with Sports package)
0°12' ± 0°12' (°)​
Camber, rear
-1°33' ± 0°20' (°)​
Suspension : General data
Wheelbase
2585 (mm)​
Front disc brakes
Disc diameter, front
312.0 (mm)​
Disc thickness, front
28.0 (mm)​
Disc thickness, front, minimum
26.0 (mm)​
Brake pad thickness, front (Including backplate)
17.4 (mm)​
Brake pad thickness, front, minimum (Including backplate)
8.0 (mm)​
Disc run-out, maximum
0.07 (mm)​
Rear disc brakes
Disc diameter, rear
274.0 (mm)​
Disc thickness, rear
11.0 (mm)​
Disc thickness, rear, minimum
9.5 (mm)​
Brake pad thickness, rear (Including backplate)
15.8 (mm)​
Brake pad thickness, rear, minimum (Including backplate)
7.5 (mm)​
0.07 (mm)​
Engine
Cap pressure (Brown cap)
1.2 (bar)​
Cap pressure (Yellow cap)
1.4 (bar)​
Cap pressure (White cap)
1.6 (bar)​
Cap pressure (Grey cap)
1.8 (bar)​
Thermostat opening temperature
75 (°C)​
Thermostat fully open
87 (°C)​
Engine
Idle speed, minimum
750 (rpm)​
Idle speed, maximum
850 (rpm)​
CO exhaust gas (At idle speed)
< 0.5 (%)​
Fast-idle speed
2500 - 3000 (rpm)​
CO at fast-idle speed
< 0.3 (%)​
Oil temperature during test
80 (°C)​
Lambda (At fast-idle speed)
0.97-1.03​
Lambda change (Delta Lambda)
0.03​
Manual transmission, EURO 4, Hatchback (Europe)
Fuel consumption, combined usage
8.40 - 8.90 (l/100 km)​
Fuel consumption, extra-urban driving
6.50 - 7.10 (l/100 km)​
Fuel consumption, urban driving
11.60 - 12.20 (l/100 km)​
Emission code
Euro 4​
Emission standard
70/220*2003/76B (2006-03-14 ->)​
CO2 average
199 - 209 (g/km)​
CO
0.907 (g/km)​
HC
0.082 (g/km)​
NOx
0.079 (g/km)​
HC NOx
Engine
Engine management (make and type)
Siemens Sirius 34​
Firing order
1 - 3 - 4 - 2​
Ignition coil primary resistance
0.5 (ohms)​
Ignition coil secondary resistance
10000 - 12000 (ohms)​
Valve clearance
Hydraulic
Idle speed
800 ± 50 (rpm)​
Fuel pump pressure
3.3 - 3.7 (bar)​
Spark plugs (make and type)
NGK PFR7Z-TG​
Spark plug gap
0.8 - 0.9 (mm)​
CHAMPION​
Spark plug gap
0.85 - 0.95 (mm)​
Number of spark plugs
4​
Oil pressure at idle speed (at 80 °C)
0.8 (bar)​
Oil pressure (at 80 °C)
3.7 - 5.3 / 4000 (bar/rpm)​
Maximum cylinder head distortion
0.05 (mm)​
Drive belt layout
Wow, very useful, thanks!
Where did you get all these pictures from? They are far more readable than the standard service manual!
Reactions: VeiRoNv2
Oh nice, I didn't know there where different manual versions other than the usual PDFs you get on the forums! Might be worth buying a copy of this, as I love reading and preparing in detail before any job :thumb:
Also i just wanted to add a few common faults and how to fix them from the same manual:
Symptom
Broken oil filter
Cause
Faulty oil pump
Solutions
Run the engine at 3000 rpm
Check the oil pressure
Expected value: 3 bar
Action required if the value is too high: > 6 bar
Renew the oil pump
Abnormal boot lid operation
Symptom
The boot lid releases when door unlocking is activated
Cause
Faulty boot lid control button
Solutions
Renew the boot lid control button
Reactions: Albert540
Front wiper/washer malfunction; Dipped beam malfunction; Rear wiper malfunction; Main beam malfunction
Symptom
After turning the ignition on:
The dipped beam comes on and remains on
Cause
Damaged wiring
Solutions
Check the wiring condition between the following components:
Light stalk switch
Wiper stalk switch
Repair the wiring
If necessary:
Renew the light stalk switch
Symptom
Clicking noise from the engine compartment
Cylinder head
Cause
Inlet camshaft:
Faulty camshaft timing actuator
Solutions
Inlet camshaft:
Renew the camshaft timing actuator
Symptom
Inoperative windscreen wipers
Note: The symptom is intermittent
Cause
Water ingress into the windscreen wiper motor
Solutions
Connect the diagnostic tool
Check the windscreen wiper parameters
If a fault is found, renew the windscreen wiper motor
Symptom
Horn failure
Windscreen washer failure
Cause
Poor contact between the stalk switches and the connector
Solutions
Wiper stalk switch:
Check the connector for damage and correct fitting
Check the connector pins
Renew or repair the connector if necessary
Clean the electrical connectors and allow to dry
