Clio 197/200 Torque Setting for Suspensions/Engine.
No fault codes are displayed; Inoperative windscreen wipers
Symptom
Cause
Water ingress into the windscreen wiper motor
Corrosion causes the wiper motor to jam
Solutions
Connect the diagnostic tool
Body control unit: UCH
Check the windscreen wiper parameters
Activate the windscreen wipers
Power steering failure; The 'STOP' warning light illuminates; A power steering warning message appears on the display; An audible signal will sound
Symptom
Power steering control unit:
Fault codes: Electronic power steering motor C1606, DF035, 5606
Computer DF035, 9346
Electromechanical steering column lock, blocked C1608, DF002, 5608
Computer DF002, 9344
Vehicle speed signal missing or invalid C1609, DF057, 5609
Vehicle speed multiplex signal DF057, D200
Engine control unit status fault C1610, DF019, 5610
Right-hand main beam headlight circuit DF019, 921C
Cause
Faulty power steering control unit
Solutions
Delete all the fault codes
If the fault code cannot be deleted: Left-hand outer sensor DF002, 9001
Power steering control unit 6-way white connector:
Check the signal on pin 2
Check the signal on pin 3
Check the signal on pin 4
Check the power supply on pin 5
Check the signal on pin 6
Power steering control unit 1-way black connector:
Check the power supply on pin 1
Power steering control unit 1-way white connector:
Check the ground on pin 1
If no fault is found
Check the CAN-Bus signal
Note: Use an oscilloscope
If the displayed value is:
Disconnect the power steering control unit from the CAN-Bus network
Renew the power steering control unit
Initialise the power steering control unit
Calibrate the steering angle sensor
Check for correct operation
Symptom
Tailgate opening fault
Cause
Moisture ingress into the tailgate intermediate connector R2
Solutions
Check the tailgate switch parameters
Check the tailgate opening parameters
If a fault is found, carry out the following check:
Check the tailgate wiring
Check the tailgate intermediate connector for moisture ingress
Symptom
Squeaking noise when the clutch pedal is depressed
Cause
Clutch pedal:
Insufficient grease
Solutions
Remove the clutch pedal
Apply grease to the clutch pedal shaft
Refit the clutch pedal
Cracking noise from the front axle; Jerky steering wheel movement; Vibration and noise from the front axle
Symptom
Vibration from the front suspension
Cause
Partially seized front shock absorber bearing
Solutions
Renew the shock absorber bearing
Symptom
The dipped beam activates when the ignition is turned on
Inoperative fog lights
The following fault code is present: Steering column switch combined circuit DF010, 9530
Cause
Faulty stalk switches
Solutions
Check the stalk switch parameters
If a fault is found, proceed as follows:
Check the wiring condition between the following components:
Multifunction steering wheel control unit
Body control unit
If no fault is found, renew the stalk switches
Fluctuating idle speed; Difficult engine start; Low idle speed; The engine stalls; (02/01/2002 - 31/12/2010)
Symptom
One or more of the following symptoms may occur:
Low idle speed
Engine stall
Cause
Carbon deposits in the throttle body
Solution
Remove the throttle body
Remove the seal
Clean the throttle body interior
Note: Use a cloth and solvent cleaner
Renew the seal
Refit the throttle body
Initialise the throttle body
Engine hesitation; Engine stall; The malfunction indicator light (MIL) illuminates; Intermittent engine starting failure; ( - 01/01/2010)
Symptom
Engine stall
Engine hesitation
Possible fault codes:
Crankshaft position sensor 1 circuit/openCardOverheating switchOil pressure sensor circuit DF005
Overheating detection: probable DF017
Driver's side rear external aerial circuit DF025
Battery Voltage DF080
Crankshaft position sensor 1 circuit/open DF154
Gear programming DF189
Invalid raw engine torque multiplex signal DF238, D12B
Cause
Possible causes:
Faulty TDC sensor
Faulty contact between the connector and the TDC sensor
Solution
TDC sensor:
Check the connector for damage and correct fitting
Check the electrical connectors for corrosion
Action required if no fault is found:
Renew the TDC sensor
The airbag warning light illuminates; Inoperative cruise control; (01/04/2004 - 01/04/2007)
Symptom
Pedal sensor circuit gang 1 DF071, 180A
Fuel pressure information DF072, 1882
Cause
Faulty clock spring
Incorrectly positioned clock spring connector
Solution
Clock spring:
Rectify any faults found
Use a repair kit
Renew the clock spring
Parts required
Repair kit: (OE Code: 82 00 483 192)
The engine warning light illuminates; The battery charge warning light illuminates; The battery discharges; The starter motor does not turn; (01/01/2006 - 08/03/2008)
Symptom
Rail pressure sensor circuit DF007, 0190
Passenger-side external aerial(s) DF034
Ignition switch sense input circuit highLeft Turn SignalsFlame off from minimum power DF013
Cause
Incorrectly tightened gearbox earth cable
Solution
Gearbox earth cable:
Clean the contact surfaces
Renew the earth bolt
Check the battery charge
Torque settings
Earth bolt: 24 Nm
Symptom
Front doors:
Noise during power window operation
Cause
Excessive play
At the points shown
Solution
Remove the door trim
Fit washers to the bolts shown
Refit the door trim
Repair time
Remove the door trim (Time: 0.20) (OE Code: 7005)
Parts required
Washers: (OE Code: 77 03 053 951)
Torque settings
Bolts: 6.5 Nm
Engine stall; Power loss
Smptom
Power loss
Engine stall
Cause
Contaminant build-up inside the throttle body
Solution
Renew the O-ring
A diagnostic tool must be used for this operation
Repair time
Clean the throttle body interior (Time: 0.20) (OE Code: 7576)
Initialise the throttle body (Time: 0.30) (OE Code: 0145)
Parts required
Aerosol spray: (OE Code: 77 11 236 177)
Symptom
Engine stall
Engine hesitation
The engine does not start
Possible fault codes: Rear right-hand wheel valve sensor DF005, 5A84
Preheating unit control circuit DF017, 0670
Camshaft dephaser circuit DF080, 1111
Thermoplunger no. 3 relay circuit DF238, 1836
Cause
Solution
Renew the connector
Check for any fault codes
Repair time
Renew the connector (Time: 0.50) (OE Code: 0500)
Parts required
TDC sensor kit: (OE Code: 82 00 673 203)
or
TDC sensor kit: (OE Code: 82 00 673 202)
or
TDC sensor kit: (OE Code: 82 00 300 322)
Faulty brake light switch
Symptom
The brake light fails to illuminate
Cause
Solution
Disconnect the brake light switch connector
Turn the brake light switch 90° anti-clockwise
Remove the brake light switch
Depress the brake pedal
Renew the brake light switch
Turn the switch clockwise 90°
Reconnect the connector
Turn the ignition on
Check the brake lights
Repair time
Renew the brake light switch (Time: 0.20) (OE Code: 7602)
Parts required
Brake light switch: (OE Code: 82 00 276 361)
Symptom
Noise from the front strut
Abnormal resistance when turning the steering wheel from lock to lock
Cause
The shock absorber bush is damaged
Solution
Check for noise or vibration:
Turn the steering wheel from the left stop to the right stop
If necessary:
Renew the shock absorber bush
Parts required
Shock absorber bush: (OE Code: 82 00 948 647)
Haven't seen a thread with all of the torque settings before,if there is one please just close this one,if not hope this is of help.
That 10nm doesnt make sense. Should it be 100nm?
I swear I looked at that like 3 times and couldn't find it.
They're tight bolts though. I'd say 100-120nm would be a safe starting point.
