VeiRoNv2
Haven't seen a thread with all of the torque settings before,if there is one please just close this one,if not hope this is of help.
Engine | |
Note: Always renew stretch bolts and self-locking nuts | |
Cylinder head | |
Renew the bolts | |
Renew the gasket | |
Stage 1 | 30 (Nm) |
Stage 2 | 155 - 205 (°) |
Valve cover | |
Stage 1 (Bolts 13, 20, 22, 23) | 8 (Nm) |
Stage 2 (Bolts 1 - 12, 14 - 19, 21, 24) | 12 (Nm) |
Stage 3 (Loosen bolts 13, 20, 22, 23) | |
Stage 4 (Bolts 13, 20, 22, 23) | 12 (Nm) |
Big-end bearing cap | |
Renew the bolts | |
Stage 1 | 25 (Nm) |
Stage 2 | 104 - 116 (°) |
Main bearing cap | |
Renew the bolts | |
Stage 1 | 20 (Nm) |
Stage 2 |
Sump | |
Stage 1 (Bolts 1 - 6) | 15 (Nm) |
Stage 2 (Bolts 7 - 10) | 18 (Nm) |
Stage 3 (Bolts 11 - 22) | 18 (Nm) |
Stage 4 (Bolts 1 and 2) | 18 (Nm) |
Sump (Gearbox side) | 44 (Nm) |
Engine oil drain plug (Renew the seal) | 20 (Nm) |
Spark plugs | 28 (Nm) |
Oil filter | 10-14 (Nm) |
Knock sensor | 20 (Nm) |
Oxygen sensor | 45 (Nm) |
Starter motor | 38 (Nm) |
Alternator | 25 (Nm) |
Camshaft bearing caps | 10 (Nm) |
Camshaft gearwheel | 30 (Nm) |
Crankshaft pulley | |
Stage 1 | 40 (Nm) |
Stage 2 | 100 - 120 (°) |
Ancillary drive belt tensioner | 50 (Nm) |
Timing belt tensioner pulley | 32 (Nm) |
Timing belt idler pulley | 50 (Nm) |
Timing cover | |
Stage 1 (Lower section) | 9 (Nm) |
Stage 2 (Upper section) | 38 (Nm) |
Flywheel | |
Stage 1 | 30 (Nm) |
Stage 2 |
Exhaust manifold (Stud bolt(s)) | 9 (Nm) |
Exhaust manifold (Nuts) | 30 (Nm) |
Inlet manifold | 15 (Nm) |
Ignition coil | 15 (Nm) |
Coolant pump | 17 (Nm) |
Oil pump | 24 (Nm) |
Engine/gearbox mounts | |
Manual transmission, TL4, 6-speed | |
Manual transmission drain plug | 24 (Nm) |
Clutch pressure plate | 20 (Nm) |
Suspension | |
Front drive shaft to wheel bearing housing | 280 (Nm) |
Suspension: Refer to 'Technical drawings' | |
Wheels and tyres | |
Wheel bolts | |
(Clean the contact surfaces and wheel bolts/nuts; lightly grease the wheel centre taper only but do not grease the wheel bolts/nuts) | |
(Caution! Do not use power tools when screwing in or tightening wheel nuts/bolts) | |
Stage 1 | 30 (Nm) |
Stage 2 (Rotate the wheel by 180°) | |
Stage 3 | 140 (Nm) |
OE Wheel fitment Information | |
General Information | |
Loosen the wheel bolts with the wheel on the ground. | |
Use sockets with protective sheaths in order to avoid scratching the alloy wheel rims. | |
Clean the hub carrier using a wire brush. | |
Coat the wheel mating face with COPPER ANTISEIZURE GREASE. | |
Pretighten the wheel bolts to 30 N. | |
m , with the wheel suspended. | |
Torque tighten the wheel bolts in order to correct torque. | |
Important Information | |
There are two types of wheel bolts, do not swap them. | |
Do not strike the surface of the wheel using excessive force as this may damage. | |
Steering | |
Steering wheel | 44 (Nm) |
Engine | |
Engine sump, including filter | 5.4 (l) |
Cooling system | 5.0 (l) |
Brakes : General data | |
Brake system | 1.0 (l) |
Manual transmission | |
Gearbox refill | 2.0 (l) |
Plug location (Drain plug) | |
Plug location (Filler plug) | |
Air conditioning | |
Plug location (High-pressure connecting pipe (H); low-pressure connecting pipe (L)) | |
Refrigerant | 510 ± 35 (g) |
Air-conditioning compressor oil, system total | 150 ± 10 (ml) |
Air-conditioning condenser (only when renewed), additional capacity (Quantity of oil recovered plus specified top-up) | 30 (ml) |
Air-conditioning receiver/dryer (only when renewed), additional capacity (Quantity of oil recovered plus specified top-up) | 15 (ml) |
Air-conditioning evaporator (only when renewed), additional capacity (Quantity of oil recovered plus specified top-up) | 30 (ml) |
Each air-conditioning hose, additional capacity (Quantity of oil recovered plus specified top-up) |
Suspension | |
Wheelbase (Hatchback) | 2451 (mm) |
Wheelbase (Estate) | 2575 (mm) |
Vehicle condition (Unloaded) | |
Ride height, front (Sport suspension) | A= 143 - 169 (mm) |
Ride height, front (Vehicles with Sports package) | A= 134 - 155 (mm) |
Ride height, rear (Sport suspension) | B= 241 - 273 (mm) |
Ride height, rear (Vehicles with Sports package) | B= 233 - 258 (mm) |
Toe-out, front | 0°00' ± 0°10' (°) |
Camber, front | 0°00' ± 0°60' (°) |
Maximum difference between the left-hand side and right-hand side | 0°30' (°) |
Castor, front | 4°30' ± 0°60' (°) |
King pin inclination (KPI), front | 9°40' ± 0°35' (°) |
Toe-in, rear (Sport suspension) | 0°10' ± 0°08' (°) |
Toe-in, rear (Vehicles with Sports package) | 0°12' ± 0°12' (°) |
Camber, rear | -1°33' ± 0°20' (°) |
Suspension : General data | |
Wheelbase | 2585 (mm) |
Front disc brakes | |
Disc diameter, front | 312.0 (mm) |
Disc thickness, front | 28.0 (mm) |
Disc thickness, front, minimum | 26.0 (mm) |
Brake pad thickness, front (Including backplate) | 17.4 (mm) |
Brake pad thickness, front, minimum (Including backplate) | 8.0 (mm) |
Disc run-out, maximum | 0.07 (mm) |
Rear disc brakes | |
Disc diameter, rear | 274.0 (mm) |
Disc thickness, rear | 11.0 (mm) |
Disc thickness, rear, minimum | 9.5 (mm) |
Brake pad thickness, rear (Including backplate) | 15.8 (mm) |
Brake pad thickness, rear, minimum (Including backplate) | 7.5 (mm) |
Engine | |
Cap pressure (Brown cap) | 1.2 (bar) |
Cap pressure (Yellow cap) | 1.4 (bar) |
Cap pressure (White cap) | 1.6 (bar) |
Cap pressure (Grey cap) | 1.8 (bar) |
Thermostat opening temperature | 75 (°C) |
Thermostat fully open | 87 (°C) |
Engine | |
Idle speed, minimum | 750 (rpm) |
Idle speed, maximum | 850 (rpm) |
CO exhaust gas (At idle speed) | < 0.5 (%) |
Fast-idle speed | 2500 - 3000 (rpm) |
CO at fast-idle speed | < 0.3 (%) |
Oil temperature during test | 80 (°C) |
Lambda (At fast-idle speed) | 0.97-1.03 |
Lambda change (Delta Lambda) | 0.03 |
Manual transmission, EURO 4, Hatchback (Europe) | |
Fuel consumption, combined usage | 8.40 - 8.90 (l/100 km) |
Fuel consumption, extra-urban driving | 6.50 - 7.10 (l/100 km) |
Fuel consumption, urban driving | 11.60 - 12.20 (l/100 km) |
Emission code | Euro 4 |
Emission standard | 70/220*2003/76B (2006-03-14 ->) |
CO2 average | 199 - 209 (g/km) |
CO | 0.907 (g/km) |
HC | 0.082 (g/km) |
NOx | 0.079 (g/km) |
HC NOx | - |
Engine | |
Engine management (make and type) | Siemens Sirius 34 |
Firing order | 1 - 3 - 4 - 2 |
Ignition coil primary resistance | 0.5 (ohms) |
Ignition coil secondary resistance | 10000 - 12000 (ohms) |
Valve clearance | |
Hydraulic | |
Idle speed | 800 ± 50 (rpm) |
Fuel pump pressure | 3.3 - 3.7 (bar) |
Spark plugs (make and type) | NGK PFR7Z-TG |
Spark plug gap | 0.8 - 0.9 (mm) |
Spark plugs (make and type) | CHAMPION |
Spark plug gap | 0.85 - 0.95 (mm) |
Number of spark plugs | 4 |
Oil pressure at idle speed (at 80 °C) | 0.8 (bar) |
Oil pressure (at 80 °C) | 3.7 - 5.3 / 4000 (bar/rpm) |
Maximum cylinder head distortion | 0.05 (mm) |
Drive belt layout |
Very useful! could do with being pinned somewhere
Stage 2 | 50 - 70 (°) |
Stage 2 | 58 - 66 (°) |
Symptom |
Broken oil filter |
Cause |
Faulty oil pump |
Solutions |
Run the engine at 3000 rpm |
Check the oil pressure |
Expected value: 3 bar |
Action required if the value is too high: > 6 bar |
Renew the oil pump |
Symptom |
The boot lid releases when door unlocking is activated |
Cause |
Faulty boot lid control button |
Solutions |
Renew the boot lid control button |
Symptom |
After turning the ignition on: |
The dipped beam comes on and remains on |
Main beam malfunction |
Front wiper/washer malfunction |
Rear wiper malfunction |
Cause |
Damaged wiring |
Solutions |
Check the wiring condition between the following components: |
Light stalk switch |
Wiper stalk switch |
Repair the wiring |
If necessary: |
Renew the light stalk switch |
Symptom |
Clicking noise from the engine compartment |
Cylinder head |
Cause |
Inlet camshaft: |
Faulty camshaft timing actuator |
Solutions |
Inlet camshaft: |
Renew the camshaft timing actuator |
Symptom |
Inoperative windscreen wipers |
Note: The symptom is intermittent |
Cause |
Water ingress into the windscreen wiper motor |
Solutions |
Connect the diagnostic tool |
Check the windscreen wiper parameters |
If a fault is found, renew the windscreen wiper motor |
Symptom |
Horn failure |
Windscreen washer failure |
Cause |
Poor contact between the stalk switches and the connector |
Solutions |
Wiper stalk switch: |
Check the connector for damage and correct fitting |
Check the connector pins |
Renew or repair the connector if necessary |
Clean the electrical connectors and allow to dry |
