changing headlight bulb???
bulb out on my clio 197, cant get my hand it to change bulb, any ideas must be common grh how a simple task can turn difficult! please help
if it is on the drivers side take the butterfly valve off to help you get your hand in further there is also a guild on the how to section
Taking the bumper off is pretty straightforward, most annoying bit is having to jack up the front of the car and remove the wheels to get the arch liners out in order to access the fixings for the bumper.
you can take the air intake pipe off using the two torx screws either side of it! once thts off you will have enough room to get you hand in
hi guys just an update managed to get at passenger bulb as in thread, changd bulb however problem is that metal clip is missing prob why it moves around and breaks, any ideas where i could get this clip help apreciated please
