I thought the ET45 offset would cause issues and require longer bolts?
You’ll probably have rubbing with 225/45 at that offsetAnother question, is there any worth running tyres wider than 215 on the wizards? Thinking about pilot sport 4.
If you’re on standard ride height you should be fine with a 225!
225’s are cheaper but personally 215s look better
"Be warned tyreleader don’t list them for a clio as some sets come with m14 holes and some come with m12 holes (5x108 m12 are Ford fitment and older renaults like Laguna etc)"
May I ask how will the m14 and m12 holes cause any issues? Sorry if stupid question...
Well, technically speaking it's as RSRowe said however I genuinely cannot understand the original quote as I've never heard of wheels having a specific hole size for different bolts/nuts, what matters is PCD - in this case being 5x108.
What I take from the original quote is you would receive the wrong FITTING KIT - so wrong bolts/nuts and spigot ring for the Clio RS 197/200 but the wheel itself would be the same.
I stand corrected. Would that be the reason why they're not listed on Autec's own website as fitting the Clio RS 197/200?No, they genuinely had different sized holes...they were predominantly made for a car with M12 holes, but then they realised that Renault owners may want them, so there are both sets floating about (as many companies buy in bulk, they might have older stock).
I bought a set a while back and from memory they were for a megane or Laguna. Search for mk 2 meg wheels. Might get luckyI stand corrected. Would that be the reason why they're not listed on Autec's own website as fitting the Clio RS 197/200?
M | Autec WIZARD 7.5x17 ET45 | Wheels and Tyres | 8 | |
R | Autec Wizard - Fitment query | Clio 200 Area | 23 | |
Sold: Autec Wizard & Slicks 17 x 7.5J ET45 | Car Parts For Sale | 3 | |
Autec Wizards | Wheels and Tyres | 7 | |
Autec Wizards - Clio Mk 4 Only | Car Parts For Sale | 2 |
