Alien Green 200 CUP
The missing bolt isn't an issue, my original engine didn't have anything there and the replacement has nothing there too. Headlights are shared with the facelift mk3 Clio so you can pick them up cheap from a breaker, I think there's aftermarket alternatives available on Autodoc or similar for £notmuch.
The spare hole in the headlight is for a plastic rivet that clicks into another plastic clip on the back of the bumper if you are wandering.
PureMotorsport engine mounts fitted. Will have all 4 stock engine mounts with with Powerflex inserts for sale.
Battery relocated, heavily inspired by the Duct3d kit. I luckily had everything left over from rewiring my mk2 several times and managed to make everything work.
Fuse boxes are in their temporary location as I wanted prove the concept worked ok. I’ll look to strip wiring loom back and relocate them better later down the line. Also need to work out an intake setup.
I’ve future proofed the wiring with another fuse box behind the centre dash panel as I’ve got some ideas moving forward.
Replaced the alternator and fitted a new belt. Pain in the arse to be honest as it has a Ktec air con delete bracket fitted using a stretchy belt. I’ve still got this Cartek battery cut off to fit now I know it all works.
