[MENTION=53925]tombate911[/MENTION]Aside from that I've been working with Compbrake a local Motorsport Engineering company on the development of a set of top mounts for the Clio to run OEM springs and any other coilovers designed around the same Diameter spring. Will also be rolling out a similar design for the Newer style top mounts with templates for cutting the top mount on the chassis and a strengthening plate to allow adjustable top mounts to be run on the newer clios. Should have the final bits from the machine shop this week and get them fitted and the car set up properly.
Hi
You had these fitted yet ? What did you manage to achieve max caster / camber ? Thanks
