looking to replace my exhaust system. Do I keep both cats and buy non res system?or lose second cat and keep first and Decat second. Then which system?
Hi Ben thanks for reply. So you've decatted second cat or left it and replaced everything after?For what it's worth Steve ive recently fitted a Scorpion resonated cat back system.
The sound is very very good and few bhp gain as well. No worries on MOT front and it's not ridiculously loud when you don't want it to be.
Hope that helps
I've got standard manifold and thinking keep second cat and fit non res system as won't have flat spot issues or mot hassle. But would decat sound better? I've only ever modded turbo exhausts never naIve got Toyo manifold, Scorpion resonated system and 2nd cat; cut back into Scorpion system. (Had no worries at all with MOT and have had no issues at all with any engine management lights on the dash).
Still not ASBO by any means - but loud enough that the droning at 70mph on the motorway did get on my old mans nerves when he rode shotgun.....but ok for me and i didnt want OTT either.
eBay sells a middle silencer delete with decat for 65 which I had considered. Don't no what it will sound like tho. Will it be just noise?
I had that setup before I went full system.eBay sells a middle silencer delete with decat for 65 which I had considered. Don't no what it will sound like tho. Will it be just noise?
No no track mode. Second car only use mainly when I blat into country roads so not a daily driver. You're saying decat and silencer delete sounds crap?I had that setup before I went full system.
Chalk n cheese.
No need to remove any cats imo.
Unless you going full track mode
Don't want akra expensedepends..akra is superior.ktec is very good so is scorpion and miltek..
I don't want it sounding like a fiesta so maybe scorpion way to goI only had silencer delete which was ok but bit raspy.
Cat back scorpion sounds deeper, more purposeful, and is even better when you really get after it
So is a 197 system identical to a 200?
Ok, I ask because on some sites is price difference between the two99.9% certain it is.
Wherever i looked for one for a 200; all were listed as 197/200 fitting.
N | ECM Fault codes can't be erased | Clio General Chat | 4 | |
new member - can't see for sale? | Clio General Chat | 2 | ||
S | Still can't cancel membership | Questions, Bugs and Suggestions | 8 | |
B | Can't remove shock/strut | Clio 197 Area | 6 | |
Ahhhhhhh | Clio General Chat | 6 |
