Right on my daily runner, a mk1 1.4 Clio 1995, it's had a constant problem with it running very hot. I'm talking about it sitting right below the red zone on the gauge. Changed thermostat, radiator, fan switch, heater matrix and water pump all to no joy. Compression test come back fine and it doesn't lose any coolant.
So after running out of ideas I changed tactics, fitted a ktr low temp rad switch but still run red hot. Now the standard and replacement thermostat has 91 degrees stamped on it, quite high I thought, so I stuck a spare 197 thermostat in it at 75 degrees and bingo the car runs cool but it only ever gets to a quatre heat up the gauge.
Are there any adverse effects to an engines performance or lifespan by running it 16 degrees cooler? Fuel efficiency seems normal and the heaters are still red hot.
Thanks!
Thanks!
