Yes it was I was just going to double check with the strap and the eye and a tape measure. As I only used a tape measure the other night.
This not appropriate for the guys that want it to stick out.
I don't think I will bother with this after all thanks Syer.
A 200mm bolt is not long enough, they usually have 65mm of thread. If you reduce the thread length to say 35mm you now only have a total length of 165 which isn't long enough.
You need to start with a 250mm bolt minimum
no worries Syer..Im not too clued up on all this so not a lot i can contribute..ask me about a teacher stuff and i will be glad to help but this is beyond me..Cheers anyway
nothing wrong with this mate..we all have our field of expertise,dont we??+1! I'm clued up on anything relating to the coach industry but anything involving nuts or bolts and I'm just winging it..
"We'd already covered this. And it was mentioned here it would end up as a 65mm thread length on the chassis end - basing the overall length at 195mm (Derived from a 200mm bolt). This was too keep 'material' and labour costs down and i was informed the 65mm thread length would cause no problems. Simple as that."
I'm trying to help having already made one of these, if it wasn't 50 miles away I'd take it out and measure it. I'll re phrase what I said - you could use a 200mm bolt but you would have to restrict how far it screwed in (maybe fill the thread with weld and grind off giving about 30mm of usable thread).
This before I welded a nut on the end
Post 9 http://www.clio197.net/threads/tow-strap-bolt.56974/#post-649199
The basic issue is: No-one has come up with anything definitive. Its all ifs, but's and maybe's for whatever reason.
So from what you're saying right there - it's not a blind-bore threaded female recess in the chassis then ?.......the thread passes right through something by the sounds of it; otherwise it couldn't be over-wound in too far - and hence you're saying the need for it to be restricted otherwise you'll lose the length.....
Is that correct ?
That's correct it's not a blind hole
For Sale: 200 Tow Strap Adaptor & Sabelt Tow Strap | Clios For Sale | 5 | |
200: Clio 200 Canning Town | Spotted | 0 | |
200T: LM14 White 200T Silvertown | Spotted | 0 | |
GW 200 Stowmarket with pic. | Spotted | 1 | |
R | Tow straps for Clio 200 | Clio General Chat | 5 |
