Straight fit no issues.
Really? That's strange..
I would expect the 200 cup to be more expensive. 197 cup, 197 non cup and 200 non cup are the same. 200 cup is slightly faster (precious little 7.5%)
I've got the 200 cup if that helps
Do you have a part number?
Guys,
Currently looking at replacing my steering rack.
My clio is a FF 197, is it possible to fit a 200 Cup Rack without issue?
Thanks,
JAM.
I'm going to be doing this soon. Where did you get it fitted and how much did it cost to fit if you don't mind me asking?
i had a cup rack fitted to my previous 197 couple of years back. straight fit. the only issue i had was the inside of the rim rubbed against the wishbone on full lock left and right.
i could never figure out how it happened because the sizes of the parts are identical. nevertheless 16mm h&R spacer sorted that problem.
Cup quick rack also on cup pack 200's? | Clio 200 Area | 6 | ||
R20 BTG - 200 Cup Track Car Blog | Projects/Progress Threads | 546 | ||
J | 200 Cup Rack | Renault Parts Direct - Official Parts Supplier | 1 | |
200 cup steering rack | Suspension, Brakes & Steering | 0 | ||
R | 200 cup steering rack | Renault Parts Direct - Official Parts Supplier | 1 |
