Larkspeed have photos on their website. Fundamentally its a round bit of metal with holes drilled in it.
Isn't this a hubcentric spacer?
I have eibach hubcentric 16mm spacers so yes, it is possible.
No no no, hubcentric means they have a recess that locates on the hub, and a protruding ring that the wheels locate on to keep them concentric...doesnt mean they are bolt to hub
Yep. http://www.performancealloys.com/eibach-alloy-wheel-spacers.aspx
These are eibach below.
However, why everyone goes for the Eibach/H&R i dont know. FK Automotive are big in the audi/vw scene and their spacers are £40 a pair, half the price of the big names and just as good quality.
Aliright, i bought some NN german made 4 pieces for around 80euros.
However i bought 20mm, as they didnt have 16mm. And he told me i can make this one smaller, but if i make it smaller then the actuall hub that holds the wheel would touch the ring of the spacer, and there would be a gap between the hub and spacers.. So it is not safe to drive it like that, as the spacer should be touching the hub 100%... Thats why i still dont get how can you have 16mm spacer on 197, and have the ring that centers the wheel. I guess people that have them just stick longer bolts, and thats what their wheel holds onto.
Any links for FK ones bud ?
personally i think you'll find that the 20mm spacers will look great anyway so no need to machine them down,imo its only 25mm spacers that look over the top
the problem you've got mate is that the spigot on the hub sticks out along way,further on the front compared to the back as well iirc,i'm sure 16mm spacers are the smallest hubcentric spacers you can buy for the mk3 clio but eibach and H&R definately fit
its hard to explain in words but once you've got a spacer in your hand and the wheel off you'll see the issue
i have 16mm spacers all round as well and yes you need longer bolts but the spacer is located on the hub spigot central and the wheel is located on the spacer spigot so that is central as well
Steering Wheel spacer/extension | Interior and Audio | 4 | ||
Pure camber/toe shims + axle spacers | Car Parts For Sale | 4 | ||
Sold: 16mm H&R spacers | For Sale | 5 | ||
Lowered on H&R's and 16mm spacers | Gallery | 15 | ||
C | 16mm Spacers | Wheels and Tyres | 2 |
