The Farrow's Nimbus F1 #472 and Ultra Red 197 *pic heavy*
Finally had a dry day to work on the Clio, all going well until I went to fit the braided brake lines... They accidentally sent me lines for a 182. Returning these and ordered some other ones
On the plus side, I've decided to go for the full kit rather than just the fronts and the short connector pipes, new kit also replaces the rear lines to the calipers too, didn't realise how they ran the lines on the Clio. Also fancied a change of colour
lil teaser...
Finally got around to finishing off the brakes! Also ended up ordering different caliper pins as the new Brembo ones instantly bent! Highly recommend the ones with the retaining pins, so much easier to fit, and no faff to remove down the line!
Took the battery off trickle charge, car started up instantly which was nice to see. Just the car couldn't detect either key card. I'm hoping they both need new batteries which are now on order.
In the next week or two the car will finally be sent off to get the rest of the work done. Jade developments reached out to me about getting all the work done so possibly sending to them, Any other recommendations west midlands?
Car is booked in for the 30th of March at Jade Developments. Now we wait...
May do a few small bits in-between
