Silverstone Edition 200 - AST 5100
Oreca Motorsport sells the carbon cards.
Never mind,i cant see them anymore,thats where i got mine from a few months back.
So booked a track day at the Ring for October which means time to make changes to the car once again.
Going more track focused over the previous clubsport style, still not sure if I'm doing the right thing as it was pretty clean as it was but ah well.
Started with the big strip out.
Took the wiring loom down to its minimum required. Went all the way to the connectors and de-pinned all that wasnt needed. Most of the tar sound deadening removed too.
Then took the car for a new timing belt, water pump and dephaser.
I got the airbag light coded out. I had no airbags connected at the time but when I disconnected the loom from the airbag ECU the light came back on so need to try get that coded out again, tough as its tricky to find somewhere with the ability near me.
Moved onto electrics and made my own battery relocation kit. Bought a deadweight industries battery to power the car.
Designed my own battery cage and printed on my 3D printer. Yes the design idea was shamelessly stolen from @RSRowe
V6 airbox was then fitted. Surprisingly managed to get all the parts new from Rsport. Mounted to an ali sheet I made to fit.
Steering rack lowered using some nuts and washers.
Onto the roll cage. Got a full bolt in MSUK cage from SW motorsport. Welding in the feet was a bit squeeky bum at times with underseal catching fire close to the fuel tank. Also removed the seam sealer from this area. Will think about doing the boot area in the future, what a ball ache it is.
Door cards bought from trackdoor cards after giving up trying to find the R3 carbon door cards. Went with the fabric strap door handle style.
With the window switches and mirror adjuster I wanted a neater look than just using the standard mounting plates. Got onto fusion and designed a new plate that houses both the switches and mirror adjuster. Re used the original metal clips and It clips perfectly onto a 2mm sheet.
Deciding wether to mount it to the door cards or run new wiring to the centre consol and have it mounted to the black space down near the handbrake. Might take the easy option.
And finally treated the car to a carbon boot. Although everyone knows carbon is super light its still shockingly lightweight.
Took measurement after measurement after measurement. Bit the bullet and cut holes into it for the aero catches.
Awaiting the lexan screen and need to make some brackets for the pins but that is all for now. Still loads to be done
I’m not sure what the solution is. I often upload images which are about 1mb each rather than the original photo. It is an old habit I have from living with a terrible internet connection - thankfully I have 1gb speeds now.
Mega. Done a wicked job!
Easiest thing to do is email the pics to yourself and select a lower quality.
Got a work around for the image issues.
Also forgot I fitted some Pure motorsport engine/gearbox mounts to replace the powerflex. I was not expecting it to be such a stark difference!
Also a SW motorsport subframe brace
Reactions: Onrus
Proper update, looks great!
How did you find the wiring strip down? I've planned to leave ours well alone for now.
Its not bad if you know how to de pin and are gentle enough. There is a huge amount of excess wiring once you get rid of the unnecessary. I've left the loom at the dash section for now and may tackle that in the future.
Reactions: EthanMenace
