You will get the gear change beep now,won't you?
Best part is that you can still hear it even if you have a loud exhaustYeah, Its amazing ;-)
I sat for about 10mins for the car to warm up and then went for a small gentle drive for 20mins and kicked its hole in on the way home just to hear the beep. Its actually very very cool IMO
Half tempted to have a look for one. A few times when involved in some 'intense' driving I've found myself bouncing it off the limiter because I didn't look for the light. A beep might be better..!
Is it just a case of getting someone with CLIP to change the mileage on the clocks?
I THINK you can only go forward (ie: UP) on the mileage using Clip or some other method i read about. Not backwards.
Other than that - it means sending off to a specialist mileage correction place.
can you do mine pls?
top job
when are you fitting the??
Deep pockets!! Great effort. Hope I’m still around when it’s finished
Where does it end? 2003 Clio 172 | Projects & Progress | 3 | ||
S | S88THL - Supercharged Clio 200 | Projects/Progress Threads | 3 | |
K | Ricambi tuning exhaust for MK3 Clio? | Clio 197 Area | 1 | |
C | Clio 197 alternator | Clio 197 Area | 1 |
