MarcB's LY Clio 197 F1 R27
Discussion in 'Projects/Progress Threads' started by MarcB, Oct 3, 2017.
  1. MarcB
    MarcB Gold Member
    292
    Scotland
    Car:
    LY 197 F1 / Trophy / Escort RST
    Well some more parts of the puzzle have come together, As you can see im getting some bits and bobs for the suspension rebuild and I will be looking for to get a lot more stuff but mainly all nuts and bolts.
    Anyway here is a small list of the stuff I picked up -
    Top Mount Covers
    Top Mount Bolts (3 each side)
    Top Shock Nut
    Rear Window Seals
    Inner Tie Rod & Boot Kit (O/s & N/s)
    Outer Tie Rods
    Vapour Blasted Hub Carriers (The white dots are just water vapour the will rub off)
    Benno, Beany and Big Ben like this.
  2. MarcB
    MarcB Gold Member
    292
    Scotland
    Car:
    Just went overboard and spent this on Bolts & Nuts.
    £249.86 and thats with discount :tearsofjoy:
    7703 002 824 x 4 (Bottom Shock Bolt)
    7703 034 274 x 4 (Bottom Shock Nut)
    7703 602 210 x 2 (Rear Subframe Rear Bolt)
    7703 602 251 x 2 (Rear Subframe Front Bolt)
    7703 602 210 x 2 (Reaction Rod Lower Bolt)
    7703 602 212 x 2 (Reaction Rod Upper Bolt)
    7703 602 210 x 2 (Radiator Support Bolt)
    7703 002 824 x 2 (Lower Arm Rear Bolt)
    7703 602 258 x 2 (Lower Arm Side Bolt)
    8200 896 829 x 2 (Lower Arm Side Nut)
    7703 034 274 x 2 (Lower Arm BallJoint Bolt)
    8200 896 829 x 4 (Anti Rotation Nut)
    7703 002 179 x 2 (Top Carrier Screw)
    1227 974 03R x 1 (Crankshaft Seal)
    7700 709 182 x 8 (Flywheel Bolts)
    7703 101 548 x 8 (Clutch Bolts)
    Benno and Big Ben like this.
  3. Big Ben
    4,828
    Herts
    Car:
    197
    I thought I had spending issues!!
    Cars going to be amazing once you’ve finished:thumb:
    Pav likes this.
  4. MarcB
    MarcB Gold Member
    292
    Scotland
    Car:
    I have found a company very local to me that does this zinc plating so thinking of getting all my nuts and bolts zinc plated as below.
  5. Gus
    Gus Platinum Member
    180
    Oxford
    Car:
    Clio 200, 182 Turbo
    Well worth it. Get as many bits as you can together and get them done in one hit. Take plenty of pictures so you know what bolt is for what.
  6. Pav
    Pav Moderator
    10,972
    Manchester
    Car:
    albi blue 197 with boost
    think i havent spent this much on bolts/nuts of any sorts like ever :tearsofjoy:
  7. MarcB
    MarcB Gold Member
    292
    Scotland
    Car:
    Well I have also managed to buy these and I collect them on Sunday morning.
    Not bad for £70.
  8. MarcB
    MarcB Gold Member
    292
    Scotland
    Car:
    So changed the headlights today.
    Was not that bad a job if im being honest after knowing how to strip a 182 bumper and a megane mk2 bumper.
    Anyway here is the pictures of the standard lights.
    New here is a few pictures of the projector lights.
    A couple of the car outside.
    Gus, SeanTheSheep and Benno like this.
  9. SeanTheSheep
    SeanTheSheep Paid Member
    430
    South Wales
    Car:
    Clio 200
    Nice one. They look much better over the silver surround ones the black sits well along side the yellow.
  10. Gus
    Gus Platinum Member
    180
    Oxford
    Car:
    Clio 200, 182 Turbo
    Makes a hell of a difference. Looks so much more modern.
    Get some pics up with the lights on .
  11. LOCKE
    LOCKE Paid Member
    2,449
    Glasgow
    Car:
    RB 182 Cup/LY 197 R27
    Lights do make a difference mate. I'm loving everything you're doing with the car but I'm not sure the 200 wheels suit the 197. Maybe in the flesh I would change my mind. Cracking job so far!
  12. Cossers
    Cossers
    697
    Car:
    Vxr astra (j) and an r27
    Potential to be the cleanest car on the forum here!well done bud
  13. Pav
    Pav Moderator
    10,972
    Manchester
    Car:
    what a bargain mate...looks miles better..cant help it but projectors suit these cars much better..:thumb:
  14. MarcB
    MarcB Gold Member
    292
    Scotland
    Car:
    Looking for some decent H1 bulbs as I dont want to go down the HID route and I also have a headlight polishing kit (Autoglym) to do the headlights to bring them back up.
  15. Chris
    Chris Bad cop Administrator
    10,546
    Needham Market
    Car:
    LY 200t
    Fantastic upgrade!
  16. MarcB
    MarcB Gold Member
    292
    Scotland
    Car:
    Right managed to get some H1 bulbs for the dipped beam.
    Whats the bulbs that are FULL beam on these headlights ?
  17. MarcB
    MarcB Gold Member
    292
    Scotland
    Car:
    Well they all arrived apart from 2 nuts and 2 bolts.
    £281 later on nuts and bolts and the car is almost ready to be booked in to get all the work done.
    As you can see I have printed off everything and highlighted it to show exactly what goes where.
    Crank Oil Seal, May as well do this while the box is off and the clutch is being done.
    Anti Roll Bar Link Nylon Nuts
    New clutch bolts
    New flywheel bolts - Part supersedes to 583
    New damper bolts & nuts
    Subframe bolts
    Top Mount Bolts and top strut nut
    Bottom arm and anti rotation nuts & bolts
    (Missing item 8 which is on order)
    Hub and hub carrier parts that had to be bought form R-Sports
    (Missing item 2 which is on order)
    Gus likes this.
  18. Pav
    Pav Moderator
    10,972
    Manchester
    Car:
    think somebody has a bolt fetish :uk:
  19. MarcB
    MarcB Gold Member
    292
    Scotland
    Car:
    Took the front end off again today to clean some bits and bobs and change all the bulbs in the Projector headlights.
    Yiannis197 and Gus like this.
  20. Chris
    10,546
    Needham Market
    Car:
    LY 200t
    As ever mark top work!
    Going to be fresh out the factory near enough soon!
  • Share This Page
