MarcB's LY Clio 197 F1 R27
Discussion in 'Projects/Progress Threads' started by MarcB, Oct 3, 2017.
  1. LOCKE
    LOCKE Paid Member
    Glasgow
    RB 182 Cup/LY 197 R27
    We'll need to meet up when your project is complete to see what I'm up against.
  2. MarcB
    MarcB Gold Member
    294
    Scotland
    LY 197 F1 / Trophy / Escort RST
    I use mine as a daily in al weather so it will Never be as clean as yours ;-)
  3. LOCKE
    LOCKE Paid Member
    Glasgow
    At the end of the day I totally respect what you are doing with the car and I would seriously like to see it when your finished.
  4. MarcB
    MarcB Gold Member
    294
    Scotland
    Well got some good news today and that is that my hub's and hub carriers are back from vapour blasting.
    I currently only have 2 pictures that are not the best but you will see exactly what thy are like now.
    Here is a picture before -
    And here is a picture now -
    So here is my list fo far -
    Parts -
    Clutch Kit & Slave. - Supplied
    Front Dampers - Supplied
    Front & Rear Springs - Supplied
    Front Top Mounts - Supplied
    Front Top Mount Bearings - Supplied
    Front Anti Roll Bar Bushes - Supplied
    Anti Roll Bar links - Supplied
    Anti Rotation Links - Supplied
    Wheel Bearings - Supplied
    Hubs & Hub Carriers - Supplied
    All Ball Joints - Supplied (Upper & Lower)
    Bottom Arms - Supplied
    Rear Discs & Pads - Supplied
    Front & Rear Seat Belts - Supplied
    Also ordering the following in the next coming month.
    8200 358 977 x 1 (Top Mount Cap)
    8200 358 975 x 1 (Top Mount Cap)
    7703 602 222 x 6 (Top Mount Bolts)
    7703 034 278 x 2 (Top Mount Shock Nut)
    7703 602 210 x 8 (Subframe Bolts)
    7703 602 251 x 2 (Subframe Bolts)
    1227 974 03R x 1 (Crankshaft Seal)
    7700 709 182 x 6 (Flywheel Bolts)
    7703 101 548 x 6 (Clutch Bolts)
    Benno and Big Ben like this.
  5. Pav
    Pav Moderator
    Manchester
    albi blue 197 with boost
    that looks better than new..how much is it to get it done pls??
  6. MarcB
    MarcB Gold Member
    294
    Scotland
    Its a friend that does all my stuff for me.
    I have a box of 182 parts to get done for my Clio 182 Trophy which will be getting dropped off in the near future as there is a lot
    Here is some stuff he has done.
    Pav and Benno like this.
  7. Chris
    Chris Bad cop Administrator
    Vapour blasting leaves some good result, why that over sand blasting? I know vapour leaves a generally better surface finish, is that why?
  8. MarcB
    MarcB Gold Member
    294
    Scotland
    Ceramic dust does not eat into stuff like sand does and the sand leaves a sh!Te finish along with not being able to get into all the cracks and things.
    There is a few companies out there that rip people off and don't use the ceramic dust as it's an expensive powder compared to others and things start to rust over time and the general finish is rubbish if using sand or another product.
    Chris likes this.
  9. Chris
    Fair enough!
    Just thought for none visible parts such as hubs, might be cheaper.
  10. MarcB
    MarcB Gold Member
    294
    Scotland
    Its my mate that has the vapour blaster so im not too fussed to be honest, Plus it also helps things the ball joints , Nuts and bolts fit perfectly rather than trying to push them into rust.
    I have a massive box of 182 parts so will post up the results at some point
    Chris likes this.
  11. Chris
    Yeah fair play! Imagine it makes things a lot easier!
  12. MarcB
    MarcB Gold Member
    294
    Scotland
    It just makes sense to do it when I have the option.
    I would be silly not to do it and it lasts a long long time.
  13. tombate911
    tombate911 Paid Member
    800
    2010 Clio RS200
    Those parts all look so good! That's a great list of maintenance you're going through with there.
  14. Foxspeed
    used to have one were i worked...we did a 911 for porsche & it won the "best of" in the dealer competition as said some of the parts looked better than new
  15. Pav
    Pav Moderator
    Manchester
    i bet..they look awesome...
  16. LOCKE
    LOCKE Paid Member
    Glasgow
  17. MarcB
    MarcB Gold Member
    294
    Scotland
    So I now have the following to collect from Renault next week.
    7701475837 x 2 (Track Rod Kit)
    7701474795 x 1 (Track Rod End)
    7701474796 x 1 (Track Rod End)
    Car is also booked into a dealership to once again go in for possibly some warranty work regarding the front lower subframe as pictured below.
  18. LOCKE
    LOCKE Paid Member
    Glasgow
    I like that you post all the part numbers Marc, very helpful.
  19. MarcB
    MarcB Gold Member
    294
    Scotland
    If you need part numbers or pictures just PM me as I have access to the OE Genuine renault parts system
    LOCKE likes this.
  20. Pav
    Pav Moderator
    Manchester
    that's handy..thanks Mark..
  • Share This Page
