Hey guys, just had the message 'top up oil level' come up on the 200. Was just wondering which oil do you use?? What would you recommend?! Thanks!
The stuff Renault put in it from the factory
Elf Evolution SRX 5W 40
Oh, and please check your oil more regularly, don't leave it until the on board computer is telling you it is low! What would happen if the sensor failed? Also you need to investigate why it's lost/using oil. My car is on 62k and has barely used a drop in the last 6k.
Oil usage is normal on cars like these. Especially if you drive them hard.
Martin: You'll have a hard time getting elf, but you could just another top quality brand of oil as long as it's the same 5w/40.
Would just be easier to drive to a renault dealer and buy it though.
I understand oil usage is normal, however i serviced my car when I bought it, i've done 6k since then and it's not dropped a significant amount.
If between services my car had used enough oil to get the on board computer to warn me it was low, I'd be worried personally.
The only car I've ever had that needed topping up between services was my old Punto GT when the valve stem seals had gone!
Motul 8100 X-cess 5w40..been using 300V Power 5w40 on some previous cars but it is almost 2X in price while i doubt the benefit for daily driving + quick spin during the weekend.
As I said above, I am currently using Motul X-cess 8100 5w40.
No problems with it, no oil consumption.
Is Fuchs Titan Race Pro S 5w40 worth extra money? It is ester based full synthetic..
http://www.opieoils.co.uk/p-68897-fuchs-titan-race-pro-s-5w-40-ester-synthetic-engine-oil.aspx
The Supersyn is still a pretty good oil, even though it's cheap. It's not what I'd recommend for a car that sees a lot of track time, but for normal road use and some track time, it's fine.
Cheers
Tim
Millers nano drive is meant to be the **** ATMnot used it my self yet but I'll be trying it very soon
| U | KW V1, Bilstein B14 or H&R Monotube Coilovers | Suspension, Brakes & Steering | 0 | |
Pencil Coils | Engine, Gearbox, Exhaust and Air Intake | 5 | |
| M | Wobble after fitting coilovers | Clio 197 Area | 0 | |
Squeaky rear Gaz coilovers. | Suspension, Brakes & Steering | 0 | |
| J | Engine a mess with Oil | Engine, Gearbox, Exhaust and Air Intake | 1 |
