Where is the bleed nipple for the clutch
Hi
Is bleeding the clutch possible? If so is the bleed nipple easy to get to. I have tried searching but can't find a definite answer. Another how to for the summer.
Yes, you can bleed the clutch!
On the gearbox you will find the slave cylinder which has a bleed nippe on it. It's not a normal nipple that you unscrew. Basically you have to pull the feed pipe out by ONE CLICK only by pressing the release button and pulling gently. One click will open the bleed nipple so you can bleed the system.
