UPC Replacement Needed?
Phenom
So driving home Thursday I had no headlights. Only dipped beam not working, got side lights, high beam and indicators.
Have checked all bulbs, fuses and relay and is all good. Flicking the switch gets the light on the dash so don't think it's a issue with the stalk as putting auto lights on still no luck.
Read a couple of other threads where people had checked everything was all okay but either had no lights or lights stuck on and replacement of the switch protection unit or UPC whatever it is.
Anyone got any other ideas before I pull the trigger on a UPC
Thanks in advance
If you have a 197 do you have cornering lights as there is a lighting computer on such a car, Also it could be the stalk that can be faulty the Renault Clip tool can indicate what you have selected with the stem controls Which would show that the stem controls are working.
