Ive just bought a 2007 197 and on hard exeliration i get a knocking/vibration from under the car. 1st i thought was exhaust so i had a look and it has a s/steel manifold and centre section. It looks like the down pipes catching the cross member and someone has ground a bit out but not quite enough.
I can sort that but it got me thinking, would it of been remapped? would it need to be remapped.
Im thinking this because if you are ticking over in nutural and you push the go peddle down quickly then the engine bogs down. Is this common?
it seems ok on the move, all be it a bit flat until you hit 6.5k.
any help would be good..
