Tyre Size and Wheel Size
My tyres need replacing shortly and I'm wondering if it's possible to get tyres which will fit standard raiders and then can be moved over to some 17x8" that I'm looking to buy in the next month or so.
Any thoughts?
I run 235 on the rear. They look funny but never had a problem. 215 is a bit of a stretch.
I have 215/45 R17 (standard size)on my 17x8 wheels.
When I first bought them I opted for 235/40 R17 which is the same diameter as standard but with a wider tyre (235/45R17 will be to tall)
I prefer the car on the 215/45's it's more lively and theres more feedback.
Ok Cheers, how much is that out by then? The website doesn't seem to say or I'm being a mong.
I suspect the latter.
when you put in the sizes its underneath the small red writing - it gives you a % of what they are from standard :tongueout:anic:
http://www.toyo.co.uk/tire/pattern/id/4651
http://www.tyrestretch.com/
that may be of some use.....
ps u cna fit any width to any rim...... all depend sif you wnat the drag racing donut look or euro look?
215 on an 8j will be fine the sidewalls will be on teh striagter side of euro styling.
tho..... all depends ont he profile
235 40 would be an option
PROFILE HEIGHT (WIDTH/PERCENTAGE)
195/50 profile = 97.5
195/45 profile = 87.75
215/45 profile = 96.75mm
215/40 profile = 86mm
225/45 profile = 101.25mm
225/40 profile = 90mm
225/35 profile = 78.75mm
235/40 profile = 94 mm
235/35 profile = 82.25mm
