I run AD08R all year round on my 197, before that I ran them on my Minis. They cope very well even in winter, they only really struggle on snow when their tread fills and they become slicks with absolutely zero grip. I know that happens to most tyres, but where my AD08Rs give up, my wife’s Mini on Continental Sport Contact 5s carry on.
Here’s my thoughts on the AD08Rs fitted to my Mini after changing from Parada Spec IIs.
Sidewall Stiffness
Definitely stiffer than the Spec 2s. I now have more feel on turn in with less wallow as I enter a corner.
Lateral Grip
I never had an issue with lateral grip with the Spec 2s in wet or dry conditions on the road and the 08 give the same levels of grip in the wet at least. Possibly more, but haven't really pushed yet just in case release agent not fully worn off.
Acceleration / Braking
I used to get wheel spin even in 4th with the Spec 2s in the rain. First impressions with the 08 is that they give far more grip when accelerating. This is possibly due to the softer compound of the 08?
Braking wise I never had an issue with the Spec 2s and so far the 08s seem on par, in the wet at least.
Road noise / ride
The Spec 2s were always noisy and the 08s are similar. However the 08s feel harsher than the Spec 2s, possibly down to the stiffer side wall. I'll take this harsher ride for the better turn in / feel it provides.
Aquaplaning
Never had an issue with the Spec 2s in this respect, but I don't do much motorway mileage. The 08s went through a decent amount of standing water today and again, no issues. I doubt however either would be that great compared to a wet weather designed tyre.
Wear
My Spec 2s have lasted over 20k miles on the R53. Way too early to say about the 08s, but with treadwear ratings of 300 and 180 respectively, I doubt the 08s will last nearly as long. However, at only £230 for a set of 4 195/50/15 tyres, I'll be happy if they only give me 10k miles.
Aesthetics
Oh how shallow I am. But I do love the tread pattern of the Spec 2s and not so much the 08s.
Both have great looking sidewalls that curve around the rim giving some decent wheel protection and make the tyres look a little bit stretched, which they're not on 15x7 rims.
Summary
All tyres are a compromise and I'm happy with what both have provided for my driving style. I've had many sets of Spec 2s on a number of cars and after today's first impressions, I'll not return to them. This isn't because they're a poor tyre for my needs, but I just prefer the feel of the newer 08.
Update
After some very wet and cold weather, I am pleased to say that the AD08Rs have performed fantastically. I know they're not winter tyres, but they haven't disgraced themselves once.
I didn't measure the tread depth when I fitted them, but they are advertised as having between 7-8mm new. I've still got 7mm all round, so if I change them at 2mm, I should get around 12000 miles a set. If however they came with 7mm new, that means they should last forever. I think mine probably came with nearer 8mm new.
The firmness in ride I felt when they were new has either gone away, or I'm just used to the harsher ride than my previous Parada Spec 2s.
They are also still quieter than my Spec 2s which always sounded as though my wheel bearings were on their way out.
Whilst I'm very careful when parking (not one kerbing in over 3 years I've had the car), the rim protectors of the AD08Rs are quite substantial and offer great protection from possible expensive kerb / wheel interfacing.
